mine flash's 4 time's then 7 time's then stay's on,that was yesterday,today it's staying off????been doing this of and on for a couple month's,is that a code 47 and what does it mean???,thank's ahead of time.
The manual says to check for DTC B1881 or B1886 to see if they show up also. It also talks about checking resistance after selecting PID P_PRTNR on a scanner.
The only helpful thing I can offer is CHECK for causes of intermittent fault at or near the passenger safety belt pretensioner connector. ATTEMPT to recreate the hard fault by flexing the wire harness and cycling the ignition key frequently.
