High Idle, After modifications
Old Sep 7, 2008 | 05:45 PM
MonatheGrona94's Avatar
MonatheGrona94
I can finally see the light at the end of an 17 month restoration on my '94 F-150. I've been running the engine, breaking things in checking and rechecking and all of a sudden the engine smoothed right out and raced to the mid 2000 range ( i have no tach, XL model). It runs real smooth much smoother than it was but i can't get it to idle down, even after warm up.
I put in a 260 cam (over the stock 240)
- Clifford headers w/ O2 sensor, EGR tube and catalytic converter
- I did remove the Smog pump (i know controversial issue)
Otherwise everything is stock either new or refurbished.
Any ideas?
Thanks
Old Sep 7, 2008 | 05:49 PM
jerg_064's Avatar
jerg_064
check codes first, look on fordfuelinjection.com for instructions on how to if you don't have a reader. Then repost and we'll be able to do a better job of helping.
Old Sep 10, 2008 | 07:00 PM
MonatheGrona94
Got the codes replaced the MAP and TPS sensors running better but I've still got a code for the power steering pressure switch. It's stil idling high and i would imagine that the powers steering pressure switch would be the problem. Where is the switch?
Old Sep 11, 2008 | 07:03 PM
Dre82s's Avatar
Dre82s
Check your idle control motor and your coolant temperature sensor just a thought!
Old Sep 11, 2008 | 07:28 PM
jerg_064's Avatar
jerg_064
the power steering code is because you didn't turn the wheel and let go of it right after you pressed the brake during during the KOER test. Ya know right after the 4 blinks.
Check IAC as dre said, and ECT. Also vacuum, could be a leak.
Old Sep 11, 2008 | 08:02 PM
MonatheGrona94
Thats what Im thinking
Old Sep 11, 2008 | 08:22 PM
quaddriver's Avatar
quaddriver
unplug IAC. while running. If the idle drops drastically....well heckfire, start there
Old Sep 13, 2008 | 06:30 PM
MonatheGrona94
Replaced the IAC and the ECT, readjusted the timing and i got the idle right down where it should be, she gurgles and rumbles like she should.
Thanks for the help
sittinlow88
16
Jan 3, 2015 06:24 PM
ky94f250
32
Jul 27, 2014 02:06 PM
northerndave
15
Jun 27, 2012 10:49 PM
rbulla
Jan 30, 2005 07:44 PM
Tony G
Jul 18, 2004 12:53 PM
