Excess black smoke
Old Sep 7, 2008 | 04:11 PM
strokin71's Avatar
strokin71
Excess black smoke
Hi all hoping someone can help with this one. Getting excess black smoke very sparatic. When it feels like it wants to smoke it looks like a pulling tractor, its not consistent. No chips or tuners only mods in signature. The turbo and EGR are working correctly(not sticking). Drove around with the tech so he could watch the reading and everything is within range. It does not matter if its very light throttle or even WOT, smokes the same when it decides it wants to do it. Then it will clear up for awhile and then do it again. Hope someone has some answer ICP is within range and injectors not spiking outta the ordinary.
Thanks
Old Sep 7, 2008 | 04:31 PM
UGA33's Avatar
UGA33
Did it actually smoke with the tech in the truck?
Old Sep 7, 2008 | 04:36 PM
strokin71's Avatar
strokin71
Yep smoked like a pulling tractor with the tech in and IDS still no unusual reading, then cleared up, next day same thing
Old Sep 7, 2008 | 05:13 PM
BowTieHatr's Avatar
BowTieHatr
egr issue or turbo issue. the egr valve can open even though it "looks" ok. watch your boost gauge when the smoke starts and tell me where it is under a hard load. start off in 3rd gear and do a wot pull and watch boost gauge. if you cant get to the mark past 20 then thats a sign right there.
Old Sep 7, 2008 | 09:08 PM
strokin71's Avatar
strokin71
Thanks for all the help, EGR and boost are fine 29 psi WOT, boost is very quick and responsive and very little if any turbo fart as they call it. Just when it gets in the mood to smoke she does argh today very little to any smoke never know what tommorrow will bring thou. To be honest it runs like a champ just concerned with all the smoke at times with The EGR and turbo on these things being so tempermental. Thanks again for the help FTE is the best
Old Sep 7, 2008 | 10:56 PM
hangon2me's Avatar
hangon2me
Try un-plugging the EGR, see if it still smokes.
Do not leave the EGR un-plugged, your MPG will
go down. Look into the EGR blocker plate and Turbo
up-pipe replacement.
Old Sep 8, 2008 | 05:16 AM
fordemt2001's Avatar
fordemt2001
Are you getting your fuel at the same station just a thought in case they have some fuel issues.
Old Sep 8, 2008 | 06:58 AM
strokin71's Avatar
strokin71
Fuel is from the same place, truck stop off of I-70 here in kansas. Always the cheapest and the roll the most fuel. Will try the EGR unplug let ya all know this evening. Thanks
Old Sep 8, 2008 | 11:15 AM
cartmanea's Avatar
cartmanea
Does it seem sluggish when it smokes? This could be the turbo starting to stick.
Old Sep 8, 2008 | 11:52 AM
jmaskew's Avatar
jmaskew
Could it be a bad injector (s)? Isn't black smoke caused by too much fuel?
Old Sep 8, 2008 | 12:50 PM
mxer0022's Avatar
mxer0022
yes it is.
black smoke=too much fuel
blue smoke=burning oil
white smoke=coolant
Old Sep 8, 2008 | 01:00 PM
cartmanea's Avatar
cartmanea
Too much fuel or not enough air.
Old Sep 8, 2008 | 01:05 PM
mxer0022's Avatar
mxer0022
this is true. lets put it this way
black smoke=running rich
Old Sep 9, 2008 | 08:37 AM
strokin71's Avatar
strokin71
Answer to all it is black smoke, and no not all sluggish actually quite the opposite runs like a champ when smoking. Gonna check the IAT sensor, have already pulled the EGR and it is very clean almost looks new after 36,000 and is opening and closing like suppose to. Question is could the turbo be stuck in the closed position?? If is wouldn't there be turbo boost lost. Not stuck in the open position never overboosting and very quick turbo response. Not sluggish at any throttle position take off to WOT. Thanks again for all the help everybody really do appreciate it.
Old Sep 9, 2008 | 12:10 PM
mxer0022's Avatar
mxer0022
if turbo was stuck, whether it was stuck open or closed, you would get a code. cause you would either be getting an over boost or under boost condition. the whole point of the VGT is it directs the exhaust flow directly at the vanes for faster spool time and then slowly adjusts as the boost climbs so the exhaust is flowing over the vanes more instead of directly at them. if it was stuck open or closed your CEL would pop on with some kind of code.
