AOD shift positions
Old Sep 7, 2008 | 11:26 AM
tip49's Avatar
tip49
AOD shift positions
I noticed after installing the Lokar shifter, that my shift stops don't seem to be that "firm" or defined when passing from park through to drive. Hiow would I improve on this so there would be no chance of finding reverse when cruising (if and when it happens)
Tom
Old Sep 7, 2008 | 04:57 PM
xfordman's Avatar
xfordman
If I recall correctly, theres an adjusting screw on the shifter at the base of the unit, where the shift handle connects. It's a allen head bolt with a lock nut. Loosen the nut and turn bolt in, it won't take much....Rod
Old Sep 7, 2008 | 07:47 PM
tip49's Avatar
tip49
Thanks Rod, I'll check this adjustment when I get home this week.
Tom
624WD
Jan 25, 2014 08:46 AM
E30tdf
Oct 24, 2013 11:23 PM
tom10e
Jan 10, 2005 02:31 PM
