dont hold me to it but i believe the drop down end link is one whole piece. well that is what was replaced on my truck from the dealer when it went bad two years ago.
could be wrong though.. so i dont know if you can put a aftermarket bushing into the end link.
Been there, done that. Yes you can replace the bushings. A couple of ways to do it. If you have access to a heavy press, the press them out. If not, do like I did. Use a propane torch, heat the rubber up until it begins to burn, cut, saw, press the rubber out. It is a PITA but worth it. If you use the heat, clean a paint the metal to prevent rusting.
I dropped off the links at a shop and picked them up tonight. I just got done putting it back together, but thanks to the ****ty instructions I don't know where the 4 washers go. i put one on each bolt first, one washer on the head side of each link, is that right? I put them in the same way as 1975.
I put in new bushings, still have a clunk in the front end. Had most of the front end parts replaced. ??
What should the sway bar bolts be torqued to?
Is the clunk the same as it was before you put the new bushings in? After I replaced my bushings, I noticed an occasional clunk when turning the wheel sharply (like turning into a driveway). I think its my inner tie rod (I think that's what its called).
The workshop manual page says the sway bar to front axle nuts should be torqued to 41 ft-lbs and the end link bolts (top & bottom) should be torqued to 80 ft-lbs. Maybe I should add that to my tech article page.
I know your already done, but a really easy way to get the old bushings out is clamp it in a vise, then use an ordinary drill and bit to hog out the rubber around the center metal sleeve. Once the rubber is weakend, it is a simple matter to pop out the metal sleeve, once the sleeve is out, then the rest of the rubber comes out fairly simply.
And for the clunk, make sure your cab mounts are tight, then check your trac bar.
