Offroad & 4x4
DRIVE LINE PROBLEMS
Old Dec 27, 2002 | 09:39 AM
Ford204x4's Avatar
Ford204x4
DRIVE LINE PROBLEMS
My ford F-150 w/ 6" lift has a vibration then I take off. Does anyone no the cause.
Old Dec 27, 2002 | 10:43 AM
xericx's Avatar
xericx
DRIVE LINE PROBLEMS
With large tires they tend to get flat spots when sitting for a few hours and when cold the take longer to rounbd them selves out.
xericx
"Apply yourself. Get all the education you can, but then, by God, do something. Don't just stand there, make it happen."
Lee Iacocca
Old Dec 27, 2002 | 10:56 AM
Ford204x4's Avatar
Ford204x4
DRIVE LINE PROBLEMS
I dont think it s flat spots. when it would vib. the whole time.I only vib on take offs..
Old Dec 27, 2002 | 11:16 AM
steve83's Avatar
steve83
DRIVE LINE PROBLEMS
Check your rear U-bolts, U-joints, & springs. If the differential rotates too much when you put a lot of torque down, then the u-joints can bind or misalign, causing vibration. Check them with the trans in Neutral and the wheels chocked so there's no bind.
Old Dec 27, 2002 | 11:20 AM
Ford204x4's Avatar
Ford204x4
DRIVE LINE PROBLEMS
I have noticed a little play in. the rear diff.. but how could that be fixed??
Old Dec 27, 2002 | 11:21 AM
85351ho's Avatar
85351ho
DRIVE LINE PROBLEMS
does this have a one peice d-shaft? two peice? reg cab? etc etc
block lift in rear?
Old Dec 27, 2002 | 11:40 AM
Ford204x4's Avatar
Ford204x4
DRIVE LINE PROBLEMS
It is a 2 peice d. shft and i have blocks in th back. do you think it could be axle wrap
Old Dec 27, 2002 | 05:47 PM
85351ho's Avatar
85351ho
DRIVE LINE PROBLEMS
the combination of the axlewrap from teh blocks and the two peice driveline is probably causing the vibes.....it should fix it if you shim the carrier bearing down some
Old Dec 30, 2002 | 01:49 PM
fsnco1's Avatar
fsnco1
DRIVE LINE PROBLEMS
could be axle wrap, how long does it vibrate for? Usually axle wrap just feels like a pause before the power transfers to the wheels
Old Dec 30, 2002 | 03:29 PM
Ford204x4's Avatar
Ford204x4
DRIVE LINE PROBLEMS
Right after I put my lift on and I geuss you could say it does feel like a palse. It stop once I get moving.
Old Dec 30, 2002 | 04:35 PM
fsnco1's Avatar
fsnco1
DRIVE LINE PROBLEMS
probably axle wrap. I have it a little bit. I really haven't had any problems with my drivetrain and I've got 60,000 mile on this lift
Old Jan 1, 2003 | 04:39 PM
MEPR's Avatar
MEPR
DRIVE LINE PROBLEMS
