Stripping parts
The first question is if there is anyone from the Houston, Texas area, have you ever used Houston Metal Stripping to strip parts? If so, did they do a good job? My second question- I am taking the front spring front hanger bracket (the one that attaches to the frame) and they still have the bushings. The stripper (mentioned above) does the caustic dip stripping. Should I press the bushings out before I take it, or can I wait and take them out after they are stripped?
Kerry
Also, if your just going to strip brackets you could just use reverse electrolysys. There is a lot of info on the search here and on H.A.M.B.
I've had good luck stripping parts at home just by soaking them overnight in an undiluted cleanser. I use Greased Lightning but I think Simple Green would work just as well.
I had some engine brackets from my early 70's Caddy engine that had 30+ years of baked on engine goop come out bare metal after an overnight soak. The stuff works great. Wear gloves though or your hands will peal like crazy in about 3 days.
I would say press the bushings out first adn remove the grease zerks that way the stripper can get in there and get all the old crud out.
Welcome to the board
Bobby
Bobbytnm- will Greased Lightning clean rust off? What I need stripped is more rust than caked on grease and crude. I have used it for many things, so I know it works well, but on rust...?
