Horrible vibration
Old Sep 4, 2008 | 08:40 PM
KaoticCreations's Avatar
KaoticCreations
Unhappy Horrible vibration
87 Ford Ranger supercab, 4x4... Has a bad vibration at different speeds. I knew that the rear ujoint on the front driveline was binding up, so I pulled the front driveline off, gonna have to beat the old spider out tomorrow, but the whole truck still shakes. I'm thinking I got a bad ujoint on the rear drive line as well. I just dropped over 1000 bucks in the darn thing at my buddy's shop when the tranny pulled itself off the engine for a hella catastrophic failure as you can imagine, so Im really hoping it's nothing deeper than a simple u-joint or something. But has anybody had a similar issue? It vibrates a "certian loads/speeds" and is getting worse everyday. I'm almost scared to drive it anymore than I need to.
Old Sep 5, 2008 | 01:49 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Sounds like it could be rear u-joints. When mine did this, I put the rear axle off the ground on jack stands and had my wife start it, put it gear and run the back tires while I watched the drive shaft. It grew at different speeds as it rotated, indicating bad u-joints.
Old Sep 5, 2008 | 02:17 PM
Beechkid's Avatar
Beechkid
Check in order..
1. U-Joints
2. Wheel balance weights & Tires for spot swelling (bubble)
3. Driveshaft balance
Old Sep 5, 2008 | 05:41 PM
KaoticCreations
Well, looks like I'll be putting it up in the air tomorrow and checking the rear drive line and I'll go from there. I appreciate your help guys.
Old Sep 6, 2008 | 09:06 AM
mihulka3's Avatar
mihulka3
Angry 2 piece drive shafts SUCK!
I've had this issue for years though not as bad as you describe. I had a driveline shop balance my shaft and replace the center carrier bearing and one of the other u-joints. I'm going down to get a set of metric 12 point sockets to get the driveshaft loose and replace the front and rear u-joints.
The driveshaft company hammered the drive shaft bolts on so tight I broke a wrench trying to get them loose. I'm fighting many other issues as well with my 88 Ranger 2WD extra cab. It's starting to get depressing. The truck would be okay if Toyota made it.
Old Sep 6, 2008 | 09:08 AM
mihulka3's Avatar
mihulka3
Tires could also be an issue. I'm replacing mine if the u-joints don't do the trick.
Old Sep 6, 2008 | 08:44 PM
KaoticCreations
Red face
Gee... I think I found the problem, take a look at this ujoint: My Photos I always figured the vibration was the binding ujoint on the front driveline. So I never looked at the rear driveshaft...until this morning. I pulled it out and the bearings on the middle ujoint are so destroyed the shafts just move loosely and ate eachother up. If it wasn't one of the joints with the bolted on straps, Ill bet they would have broken months ago. I think it was all caused by the support carrier bearing which is just deteriorating. The rubber is so cracked apart I could probably shove my finger through it. lol, crappy deal. I should have looked a long time ago and I probably wouldn't be having to replace basically the whole drive line. Although I probably would have found this on my own this morning when I finally looked, I appreciate your help guys. So now I gotta decide whether to take my chances grabbing a rear drive line from the scrap yard or spend the 270 dollars on a brand new one and a new center support bearing.
Old Sep 7, 2008 | 12:49 PM
Ben Marshall's Avatar
Ben Marshall
As long as you put in new u-joints and a new carrier, Id go with a scrap yard driveline
Old Sep 7, 2008 | 03:20 PM
KaoticCreations
Well, I hit one of the local scrapyards today and they only had one supercab, which just happened to be missing the entire drivetrain...tranny, transfer case, driveshaft...all of it. All the other scrapyards are closed today, so I'm gonna try about 6 of the others that I haven't hit yet tomorrow. Otherwise it looks like I'll be seeing about having it rebuilt.
Old Sep 7, 2008 | 03:22 PM
KaoticCreations
Oh ya, and I can't even get a new driveshaft from any of our local parts stores...not one. I don't want to spend that much on it anyways, so hopefully I'll find one tomorrow with a little luck
