ok I got dome light and daytime lights fixed, the headlight switch went bad.
BUT I still have power to my window controls all the time, keys in hand , with door open.
The lights are on in the switch panel, and the windows will roll up and down.
What controls that???
Megawatt00 your link for the ebsco quit working and I tried library for both but it still dont work.
I would say either a gem or a stuck relay. I'll look at the print and see what feeds it. Did you bookmark the page? Make sure you save the workshop manual also. Great reference
It must have been water from all the rain.
Because i started it up left it run for 1 hour plus with the heater on full blast, and now everything works as it should.
I have heard that it leaks on the back of the fuse box, to the relays, to the GEM. A few guys have found the leak by running a hose over the windshield and watching for leaks.
