Stumped
Old Sep 4, 2008 | 06:43 PM
ono_55's Avatar
ono_55
Stumped
I posted in the bronco ll form but no luck yet. My son has a 1990 bronco ll with the 2.9 it was running fine till he changed out the postive cable to the battery, now it won,t run, it turns over. No fire to the plugs their is weak spark at the coil when the key is turned to the crank position and when you let it go back to the run position. He has changed the coil with a spare, he has changed the modual on the side of the distributer.
Iam stumped any ideas as what the problem might be. Thanks Forgot to add it has the TFI-IV ignition system.
Old Sep 4, 2008 | 09:26 PM
Franklin2's Avatar
Franklin2
Take a testlight, and probe the + wire of the coil while the key is in run and in start.
Old Sep 5, 2008 | 12:52 AM
ono_55's Avatar
ono_55
We did that last night and again tonight,have power to the coil.
Old Sep 5, 2008 | 12:54 AM
ono_55's Avatar
ono_55
That makes me think, that the coil we put on is bad
Old Sep 5, 2008 | 12:40 PM
subford's Avatar
subford
Sounds like he may have left the wire off that runs from the starter solenoid to the TFI module on the distributor.
Put a test light on the coil tach (-) wire and see if it is flashing while you crank it.
Also check over that coil plug real good as I have seen a lot of these with a bad plug doing this.
