Sponsored by: Kumho
Wide Tires
Old Sep 4, 2008 | 05:32 PM
just-n-time's Avatar
just-n-time
Talking Wide Tires
How do you tell what tire you need when you wish to go fatter on the rear, and what off-set you need to keep it under the truck?
Old Sep 4, 2008 | 07:20 PM
riggz's Avatar
riggz
It would help to know what truck and what size comes stock.
Old Sep 5, 2008 | 09:27 AM
just-n-time
77 Ford custom
77/ with 275/75R/15
Old Sep 8, 2008 | 04:51 PM
just-n-time
Ok lets try this another way, how do you determine the offset needed in a wheel when you use a wide tire?
Old Sep 8, 2008 | 11:57 PM
riggz's Avatar
riggz
I would say for every inch wider you can assume about 13mm more of positive offset to push the wheel back under the truck. It kind of depends on how much room you have on the back side of the wheel. If you go with a wider wheel to accompany the wider tire you would want to increase the backspace aka going with a more positive offset.
Old Sep 10, 2008 | 06:58 PM
just-n-time
thanks I found the method to use at wwwwrsracing.com/tec-wheel.
diamond mike
Nov 2, 2011 11:06 AM
awq134
2009 - 2014 F150
Jan 24, 2011 09:26 AM
bigblackf350
Nov 5, 2010 01:55 PM
stevorino
All Things Towing
Jun 22, 2008 04:19 PM
thdavid
2004 - 2008 F150
Dec 30, 2005 08:57 AM
