Wheres the best price on a 6637 filter? Or is it an OEM part from the stealership? Im still running a stock setup. (listens for sand sucking through) Thanks Ed
I didnt have to use a clamp for my 6637, I used one for where the rubber intake tube connects to the 4" piece of ss pipe, but where the pipe connects to the 6637 it just slid inside the end of the filter really tight and i just sealed it with a good silicon and placed it where it will rest(it sure wont be moving due to me removing the rear half of the battery tray and stock filter housing) and let it set up and cure. once it cured I can lift the filter up and check underneath the filter and it still stays sealed, that way I dont have to worry about the clamp not holding or binding. Ill try to post a pic later so everyone can see my set up.
Schlepprock
