Offroad & 4x4
Bigger gears
Old Jan 7, 2003 | 03:36 PM
blownbronco's Avatar
blownbronco
Bigger gears
Hey guys, I'm ging to put bigger gears in my truck probably 4.10. My only two questions are will putting those gears in disable my Trak-Lok, also will those gears fit in the differential housing.
Oh, one more question I think i'm going to put a locker in the rear. What brand do you guys reccomend. Also will that fit in the case with out a problem??
1990 Ford Bronco--- 3.55 Trak-lok rear axle, dana44 front W/ Eaton locker!!!
Old Jan 7, 2003 | 03:42 PM
DCSpecial's Avatar
DCSpecial
Bigger gears
If you want to know what gears and lockers are available for your axle check.
www.precisiongear.com
www.reiderracing.com
www.drivetraindirect.com
www.ringpinion.com
www.drivetrainwarehouse.com
These are just a few places sell gears, install kits, and lockers
The strongest, best locker IMO is the Detroit.
Or, if you want a selectable look into an ARB or wait to see if the Detroit Electrac will be available for your application soon.
Hope this helps.
Old Jan 7, 2003 | 04:28 PM
PHS79's Avatar
PHS79
Bigger gears
When I regeared my truck I had to get different carriers in order to fit the 4:10's. The lowest that you can go would be 3:73's with out replacing the carriers. Go with the Detroit, wouldn't traded mine for the world.
Old Jan 7, 2003 | 06:59 PM
motobub's Avatar
motobub
Bigger gears
Hey BlownBronco,
Is the Trak-lok a selectable locker? How much did it cost?
Thanks
-Lars-
Old Jan 7, 2003 | 08:08 PM
blownbronco
Bigger gears
The trak-lok in the rear is from the factory. It's not selectable. My front Eaton Locker is selectable!!
Old Jan 7, 2003 | 09:18 PM
bigf150's Avatar
bigf150
Bigger gears
Detriot locker all the way
Old Jan 16, 2003 | 01:24 AM
85351ho's Avatar
85351ho
Bigger gears
[updated:LAST EDITED ON 01-16-03 AT 02:25 AM (EST)]lincoln and miller make a cheap spool
prt # 6011, 7014, or 7018
Old Jan 16, 2003 | 05:51 AM
mooktank's Avatar
mooktank
Bigger gears
