1993 Ranger skipping problem
Old Sep 3, 2008 | 07:56 PM
chuckwluv's Avatar
chuckwluv
Here's the details. 1993,3.0, auto,130,000 mi.,4dw.. New wires, plugs, cap,fuel filter and rotor. Skips on takeoff and seems to clear up while constantly accelerating. When the speed levels off it begins to skip hard and shudder until you accelerate again.When backing up , it shudders and I can smell raw gas. No check engine light, and the Cats have been gutted so they are straight thru. This condition occured before the cats were altered!Overall lacks any kind of power! Anyone with any ideas!
Old Sep 3, 2008 | 09:22 PM
MikeB 88's Avatar
MikeB 88
Did it do this before the wire, cap and rotor change? Are the wires on tight at both the plug and cap? Is it possible that your new cap could have a crack in it? Is it possible the fuel filter got installed backwards by accident?
Old Sep 4, 2008 | 08:37 AM
chuckwluv's Avatar
chuckwluv
The crack in the new cap is possible. The wires are secure at both ends and the filter is on correct. It was doing this before I started changing parts.
Old Sep 4, 2008 | 04:10 PM
87 XLT's Avatar
87 XLT
This should be turning on the check engine light. Have you pulled the codes?
Since you are smelling raw gas, try pulling the vacuum hose off of the fuel pressure regulator. Is it wet with gas?
Old Sep 4, 2008 | 07:08 PM
chuckwluv's Avatar
chuckwluv
No check engine light ( and it does work). Cleaned the MAF tonite and no change.
Old Sep 5, 2008 | 01:29 AM
foxhopper's Avatar
foxhopper
Just for the heck of it, check under the hood when it is dark for wires arching. You might even try spraying a fine mist of water on them while it is running. If your cap is cracked a spray around it should cause it to shudder. I had a similar problem a couple months ago and had changed everything like you have. Come to find out one of my new wires was defective. Pretty easy check that doesn't take but a minute. It probably isn't the problem, but?
As far as the fuel smell...Did you replace the PCV valve or check the vacuum lines going to the fuel charcoal canister and return lines?
HartleyJ
Feb 29, 2016 07:49 AM
murraycookies
Oct 5, 2015 07:09 AM
Armyguy1993
May 14, 2015 09:33 PM
bravo26
1997 - 2003 F150
Dec 1, 2013 07:58 PM
Mitch1407
Nov 26, 2010 08:46 AM
