1990 Ford F150 L6
Old 02-28-2016, 06:51 AM
HartleyJ
HartleyJ is offline
HartleyJ is starting off with a positive reputation.
1990 Ford F150 L6
have been dealing with studder and hesitation when going 35-45 mph. when I accelerate the truck smooths out and picks up speed good when I take foot off the gas it coasts smooth. ONLY WHEN TRYING TO MAINTAIN THAT STEADY SPEED the shudder gets pretty bad at times.
within the last year or so ive replaced fuel pump and relay, plugs wires, distributor w/ cap and rotor ICM, ignition coil, new battery. truck starts up fine and idles ok sometimes skips when idling. now, I live in an apartment complex not alot of room to work when I changed the fuel pump I did not drain the fuel tank and clean it out so I've always been worried about this sucking up dirt or whatever was in the bottom of that old tank. someone help! LOL
Old 02-28-2016, 09:42 AM
Lead Head
Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Well a misfire at idle could also be a misfire while driving, which can cause shuddering once the torque converter locks.
Next time it starts shuddering, put your foot lightly on the brake pedal - just enough so the brakes drag very lightly and the brake lights come on. This will unlock the torque converter. See if the shuddering stops when you do that.
Old 02-29-2016, 07:49 AM
greasemonkeyfromky
greasemonkeyfromky is offline
greasemonkeyfromky is starting off with a positive reputation.
I would clean the egr and make sure it works properly. Had same issue with mine after the cam install because i deleted it, lol. Mine was 95 with the speed density bs though. Idk just a cheap fix if that is indeed it.
nateba113
10-20-2017 10:23 AM
whisler
64
02-06-2017 04:51 PM
DentsideCurtis
11-08-2016 10:36 AM
rews2
03-01-2016 05:25 PM
lemonshindig
22
01-30-2016 09:26 AM
Quick Reply: 1990 Ford F150 L6
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
