Yellow Alt. wire, where does it go to?
Old 06-10-1999, 03:42 PM
Bogn's Avatar
Bogn
Bogn is offline
I have a 83' Bronco with 300-6, where does the yellow wire off the alternator go to?
Old 06-10-1999, 04:07 PM
Bogn's Avatar
Bogn
Bogn is offline
I just found out it is the stator wire, where does it hook up to. Its kinda yellow with a black stripe
Old 06-10-1999, 10:30 PM
Mulletwagon's Avatar
Mulletwagon
Mulletwagon is offline
Assuming you have an external regulator and a dashlight rather than an ammeter, the stator wire goes to the "s" terminal on the regulator. If you do not have a dash light and instead have an ammeter, the stator wire from the alternator is not used.
Old 06-11-1999, 10:23 AM
Bogn's Avatar
Bogn
Bogn is offline
I have a Amp meter, so I can just take the wire off the alternator and forget about it? Kinda funny that mine even has this wire...... I wonder where the other end goes......
Old 06-11-1999, 02:58 PM
Mulletwagon
Think so. If your regulator has four terminal tabs, only three should be used. The "I" terminal should not be used. On an indicator light system the "I" would go to the indicator light, the "A" is a 12 volt source, the "F" is the field current that goes to the alternator, and the "S" would be connected to the stator terminal at the alternator. On an ammeter system 12 volts from the ignition switch is directed to the "S" tab; and the stator terminal on the alternator is not used. If your alternator stator wire is going somewhere it must be to something that needs a 12 volt source only when the engine is actually running. If everything is working OK wouldn't worry. I would like to know too where the yellow wire goes though !!!
Old 06-21-1999, 08:28 AM
Chris Custer
Guest
Posts: n/a
Old 12-28-2008, 03:15 AM
crazedfox's Avatar
crazedfox
crazedfox is offline
If,
__it's not too late, here.
In truck.
Basic diagram
Trevin
09-26-2020 07:43 PM
Marine5811
24
04-23-2018 03:23 PM
FuzzFace2
12-24-2016 06:25 PM
Fordication
11-21-2016 05:56 PM
RandyP63
05-02-2016 01:36 PM
Quick Reply: Yellow Alt. wire, where does it go to?
