AC / 4x4 issue
Old Sep 3, 2008 | 12:17 PM
K9BELLA's Avatar
K9BELLA
AC / 4x4 issue
This past Saturday I used 4 wheel drive backing my camper up a hill in a field. My 4 wheel drive disengaged and I drove home about 20 miles without the camper. The next day I drove about a mile and the front end was popping from the hubs. Put it in the garage to check them and found I had a bad wheel bearing on the passenger side. I ended up replacing both but now I have another problem. My AC is going from the vents to defrost while accelerating. Any ideas?
Old Sep 3, 2008 | 02:42 PM
ReAX's Avatar
ReAX
Vacuum leak? The diverter doors in the a/c and heat system run off vacuum, and under acceleration you have less engine vacuum. This vacuum shouldn't have anything to do with the hub vacuum, it comes from another source.
Get a can of starting fluid or WD40, with the engine running spray around the vacuum hoses in the engine bay.
Old Sep 3, 2008 | 06:47 PM
K9BELLA's Avatar
K9BELLA
I think I figured it out. I pulled the vacuum lines that run to a large black box behind the battery and connected them directly to the line that runs into the vehicle. The AC worked as it should. After checking the lines I found that when I disconnected and capped the ones that run to the hubs my AC also worked fine. I took the top off the unit that runs to the hubs and found what looks like a filter inside. It almost fell apart in my hands because it was rotted. I assume I need to replace the unit that runs to my hubs. My 4 wheel drive is no longer working. Does anyone know what this part is called? Thanks in advance.
Old Sep 3, 2008 | 08:38 PM
71-4R3SONS's Avatar
71-4R3SONS
The two links below should answer your questions...
Guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Guzzle's 4x4 Needle Bearing Maintenance Web Page
Old Sep 4, 2008 | 11:19 AM
rlh68050's Avatar
rlh68050
IMO, loose the ESOF hubs and install some nice manual Mile Marker or Warn hubs. You will be eliminating the vacuum auto hub feature, but you will never have to wonder if your hubs are engaged or not.
