bad reaction, can it be redone???
Old 09-03-2008, 07:44 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
If bio fails the 3/27 test can it be redone or is it just trash? I tried KOH for the first time and it failed. I've never had trouble with the NaOH but I got a partial reaction with the KOH. I don't want to lose this 30 gal but I don't want to run it in my trucks either, so can it be saved??it made biodiesel it's just not clear and when washed it just turns to mayonase
Old 09-03-2008, 08:41 PM
empiretc's Avatar
empiretc
empiretc is offline
what did you use as a base for your koh?
Old 09-03-2008, 08:51 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
I used 7grm for my base but I titrated with Naoh solution going on what a friend said. I guess I should have run the test with KOH solution.
Old 09-03-2008, 09:50 PM
empiretc's Avatar
empiretc
empiretc is offline
YES. definitely. you titrate with the lye you will be using in your process. that was the source of your problem.
base for KOH is 8.
read towards the bottom here:
Washing Biodiesel and Dealing With Problems - Collaborative Biodiesel Tutorial
big poppa
69
08-28-2009 09:28 AM
Knotwild
Bio-diesel, Propane & Alternative Diesel Engine Fuels
05-14-2009 03:03 AM
whiteaddiction
02-02-2009 12:02 AM
Murphy2000
03-31-2007 06:52 PM
jblueep
Electrical Systems/Wiring
10-19-2004 08:20 PM
Quick Reply: bad reaction, can it be redone???
