460 longevity
Old Sep 3, 2008 | 08:30 AM
cscott952's Avatar
cscott952
460 longevity
I'm considering buying a F250 4x4 w/ a 460. How many miles do the engines typically last? I plan on performing a compression, vacuum, and oil pressure test, but would still like to know how long the 460 TYPICALLY lasts. I realize that varies with maintenance, usage, etc.
Old Sep 3, 2008 | 08:47 AM
northern 7.3's Avatar
northern 7.3
Temporarily Deactivated
i had one untouched with 380 000 km's so that would be...236 000 miles according to my calculations and it still ran good lots of power. that was an 85 though still had a carburetor
Old Sep 3, 2008 | 10:36 AM
cscott952's Avatar
cscott952
The truck in question is a '92. Anything that I should watch out for? It's got ~120k on it.
Old Sep 4, 2008 | 04:55 PM
G/T's Avatar
G/T
i have the 88 4x4 c6 460 with almost 300,000. 2 weeks ago i had to change the water pump an install a new rad.thats the most i have done so far. now i'm replacing front rotors an wheel bearings.but if you take care of it,it'll take care of you.
Old Sep 4, 2008 | 09:56 PM
gweeds's Avatar
gweeds
The rest of the truck will fall apart long before the engine does, but as far as actual functionality goes, they last forever...
Old Sep 5, 2008 | 10:18 AM
framerboy's Avatar
framerboy
I have owned a few f-250's with the 460 including my current ride which I plan to keep forever. The engine is very reliable, has adequate horsepower and torque, but must be considered a truck engine. They really inhale the gas. My current truck has about 227,000 on it with the usual repairs. I get about 10 mpg around town and 12 mpg on the freeway. I will be replacing it with a smaller truck next year as my work needs have changed, but I like it so much I won't let it go.
Old Sep 5, 2008 | 08:46 PM
Dustin1690's Avatar
Dustin1690
Oh yeah I agree these year of engines 300 302 351 460 seem to go forever even when driven hard a lot and stuff
Old Sep 6, 2008 | 02:34 AM
stngh8r's Avatar
stngh8r
460 in stock form is a durable, low rpm, grunt engine capable of very high miles.
Gas mileage is obviously a concern. Of course one could be abused to the point that its life span is greatly reduced, but from the testimonies I have heard they are capable of 200k easily and 300k is not unheard of.
Old Sep 6, 2008 | 03:26 AM
DJdemon6696's Avatar
DJdemon6696
Originally Posted by UTfball68
Sure these things can run 300,000, but to me it's easier to fix it before it's broken.
if it aint broken dont fix it
a friend of mine has 220.000 miles on his 91 F250. 460
mine 351 has 260.000 miles still pulling strong
Old Sep 6, 2008 | 07:47 AM
jarod17's Avatar
jarod17
My '96 F-250 had 316,000 mile on it when I had to take to get the motor replaced. All that was wrong with it was blown head gasket. Ran for 2 months with coolant pouring into the cylinders before it gave out.
I would have done it myself but did not have a place to do the work and it was cheaper to have the motor replaced than to have the head gaskets replaced. Still haven't figured out why but...
perkis
1997 - 2003 F150
Nov 7, 2020 10:00 PM
junkkingranch
May 15, 2017 10:48 AM
shameless
Nov 23, 2015 04:53 PM
landtortise89
15
Sep 19, 2014 07:05 PM
Cduff
Aug 26, 2014 09:22 PM
