rough running 302
Old Sep 2, 2008 | 07:22 PM
anj_nelson's Avatar
anj_nelson
Exclamation rough running 302
Have a 1993 f150 w/ a 1986 302 car motor recently put in it.. it runs but is very rough,when i give it gas it pops through the intake,3 out of 8 spark plugs are hot the rest are only warm,can anyone PLEASE tell me what the problem is?
Thanks John
Old Sep 3, 2008 | 06:36 PM
anj_nelson's Avatar
anj_nelson
can this be a bad timing chain?
Old Sep 3, 2008 | 08:48 PM
doug1222556's Avatar
doug1222556
Sounds like a timing issue to me. Check your wire routing and timing. Could be fuel related as well.. check fuel filter, check for fuel pressure and flow.
Old Sep 3, 2008 | 10:03 PM
Conanski's Avatar
Conanski
Check compression on all cylinders.
Check that all spark plugs are firing.
What car did the motor come from?
Old Sep 4, 2008 | 03:09 PM
anj_nelson's Avatar
anj_nelson
I think it came from a 1986 mustang it had aluminum valve covers on it and it has roller lifters but i dont know anything else about it
Old Sep 5, 2008 | 09:13 AM
Conanski's Avatar
Conanski
OK.. so what firing order do you have the plugs wired for? I'm pretty sure that motor requires the HO firing order 13726548.
Old Sep 5, 2008 | 05:49 PM
anj_nelson's Avatar
anj_nelson
tried that order and it won't even fire the intake that was on it just said 5.0 their was no H.O. on it must not be a mustang motor i don't know . But thanks for all the help i need it.
Old Sep 6, 2008 | 05:13 PM
anj_nelson's Avatar
anj_nelson
i guess i am a big air head that firing order worked the motor sounds great thanks for the help again JOHN
