I OWN A 04 F350 DUALLY DIESEL,,CAN i HAVE YOUR OPINIONS ON WHICH EXHAUST SYSTEM i SHOULD NOW UPGRADE TO. I ALREADY HAVE AN EDGE MODULE,,AFE COLD AIR INTAKE,,AUTO METER TRIPLE GAUGES,,BOOST,,PYRO,,TRAN TEMP. SHOULD I GO TO A FULL 4 INCH SYSTEM,,OR GO BIG WITH A 5INCH? AND WHAT MAKE OF SYSTEM???
P.s.,,also Should I Delete The Cat And The Muffler??? What Will Doing This Do To The Engine? Or Smog Emmisions? Will It Pass A Smog Test Like This?
I believe you can delete the muffler and still pass smog not for sure though. If you can I strongly recommend getting rid of them it does wonders for EGT's
As far as size 5" is pretty pointless unless your pushing some extreme hp #'s
brand is very debatable I've been happy with my mbrp still looks like new after 5 years, but to each his own.
