another 5 speed trans question
Sep 2, 2008 | 04:34 PM
is there a gasket that needs to go on the bell housing? napa didnt have one so now im confused. also could i just get away with rtv being it doesnt come in contact with the atf? if it does need a gasket i guess i would need to go to ford because napa doesnt have crap.
Sep 2, 2008 | 06:04 PM
A 5 speed as in a Mazda or ZF?
Some models have used a steel block protector plate behind the flywheel that is held by the bell to the block.
There is no reason to have a gasket or rtv between the block and bell for either a manual or automatic trans.
There should be no oil/atf/anything inside the bell except the clutch (or TC for automatic) and associated parts.
Sep 2, 2008 | 06:49 PM
sorry its a mazda 4x4 trans.
Sep 2, 2008 | 07:06 PM
Is this a new install or R&R? If R&R, you should have all the parts you need. No gasket, rtv or ky needed.
Sep 2, 2008 | 07:29 PM
its an r&r but it already had everything seal wise taken off already.
Sep 3, 2008 | 01:55 AM
There's no gasket between the bellhousing and the block.
Sep 3, 2008 | 06:08 AM
Sep 3, 2008 | 05:32 PM
if i really wanted to could i just use rtv to seal everything up instead of buying gaskets?
Sep 3, 2008 | 05:35 PM
I don't know why this is so hard to understand.
There is no gasket to buy, and there is absolutely no need to use RTV there, either.
