Glow Plugs,Up-pipe dounuts, POR15
So I am getting close to installing my new used motor into my truck, but wanted to take care of a few things while the motor was on the ground, rather than sitting in an 8' truck.
Where can I find Motorcraft GP I remember reading somewhere to buy them other than ford, but have since forgot. Oh Fords price with my discount $118. Is Motorcraft the only trusted GP for these trucks?
The up-pipe donuts I want to install are the small block chevy ones, but all I have is a carquest part number, anyone else find them somewhere else?
Where do I find POR15, the oil pan on the newish motor is rusted, so I am going to sand it down and paint it, but I am having difficulty find the POR 15. Any suggestions?
Thanks in Advance.
Thanks in Advance.
As far as the uppipes forget about trying to replacing the dounuts! Get the bellowed uppipes from Int. or from one of our sponsers!! No more leaks! Do it right the first time!!! Also replace the orings on the pedistal (4 of them total) the 2 under the pedistal and the 2 on the top where the turbo mounts!! Also I would think about putting the WW in while you have the turbo off!!
on
Here is a link for the GPR. Welcome to guzzle's Stancor GPR replacement Mod Web Page It is a much heavier duty version than stock.
The stock up-pipe system has not failed on me once. The up-pipes are in good shape, they were not leaking but wanted to replace the donuts anyways, along with get the bolts that are heat rusted in off while it was on the ground. $50 is much less $350, and since this motor is not going farther than a chip, it will be fine. That's what the motor on the stand is for.
Thanks for the suggestion on the WW, and using the bellows, but I have had very few instances where I surged my stock 02 turbo with the chip, and if it did surge I just let out a bit, or drop it down a gear to get around surge. I also always replace the pedestal o-rings, since thanks to McMaster carr, I have 10 more sets of orings at the same price ford tried to charge me since I needed them badly and there is only one place around open 24 hours.
Anyways I found a carquest around me, and here is the part number for the up-pipe dounuts for a small block chevy, they are a bit bigger, and make for a better seal. Car quest number : F1750 GM.
From another site:
Just an FYI for anyone wondering, or someone who happens to search and finds this thread on the donuts up-pipe what to use.
The oil pan Is not rusted badly, thanks to a EBPV leak(fixed now with my gutted pedestal), pretty much let it get pretty rust proofed in mostly. There are just a few small spots I want to fix before it gets bad. Guess I shoulda said rusted a little bit lol. I may have to order online if I can't find it anywhere else. My old pan is also in good shape, small rust issues, but if I keep trying to sand this pan down, and it does not cooperate, Im taking my old pan, blasting it, then painting it. Its not a huge rusted spot, just a few where the oil couldn't get to lol.
The glow plugs are still my concern. See I don't understand why the price skyrocketed? I will try to call autozoo even though they don't even list them being a motorcraft plugs maybe their online site it wrong. The autolites can sit and rot. Maybe thats why the price increase. Im checkin Ebay next for plugs. I am not in a hurry yet on my truck, so I am taking it one step at a time.
Thanks for the help! If anyone gets any more insite on the glow plugs or if I find anything fell free to post it up. Just spend $100 in oil, trans fluid for the PS, and diesel kleen, since I know some people think its useless, I want to run it through once to get any crap outta the system. Another $100 will go towards the damned coolant next week. That stuff is expensive, but love the not have to check it. Walmart is being my favorite place to shop lately.
From another site:
You MUST have that part number, not a "Suitable Sub" because they are graphite, and softer, so they crush better. The newer ones are harder, and will not crush sufficiently.
Here's a set for 60 bucks and change. Wow the price sure went up.
eBay Motors: 1994-2004 7.3L DI Powerstroke Ford Glow Plugs zd 11 (item 270270119094 end time Sep-07-08 12:15:52 PDT)
