Sponsored by: Auxito
Chip and Supercharger
Old Feb 5, 2001 | 04:47 PM
del97f150's Avatar
del97f150
Will the Diablo chip work with the powerdyne supercharger? They say you do not need one but will it work with it? Hoping they do becuse i want the shift improvements from the chip for the tranny.
Old Feb 5, 2001 | 07:34 PM
D's Avatar
D
The chip will work with your Supercharger if it has been custom programmed for that supercharger. We can normally gain another 30-60 horsepower custom programming a chip for your blower. I am not sure which supercharger kit you have and how the kit fools the ecu into running the engine rich. Anytime that you add boost (air) you must also add fuel. More air with the same amount of fuel could lead to a fatally lean burning engine. I would not recommend running a stock chip of any manufacture with a supercharger added.
Later
Danny
Old Feb 6, 2001 | 03:34 PM
del97f150's Avatar
del97f150
It is a powerdyne PART: K10407-101 6psi boost.
Old Feb 6, 2001 | 05:43 PM
D's Avatar
D
I am a bit familiar with that kit, 6# boost. The only problem with that kit is in the way extra fuel is added to the engine. The larger fuel pump raises the fuel pressure across the entire rpm range. That kit does not alter the timing or change the fuel curve to allow for less fuel because of less boost at low rpm and incremental raises in boost throughout the entire rpm range.A custom chip will add about 35hp and 45 ft/lb torque. I will need to know your fuel pressure at idle and max fuel pressure. We can gain quite a bit of power on the low end by altering the timing.
PS... I am a Powerdyne Dealer.......
Later
Danny
Old Feb 7, 2001 | 07:05 AM
tpietersz's Avatar
tpietersz
LukeStreeter
Ford Truck Parts for Sale
Jan 6, 2016 11:02 AM
lizardking1
2015 - 2020 F150
Apr 10, 2015 09:31 AM
jps47
Oct 19, 2013 12:45 PM
woodsman1991
Modular V10 (6.8l)
36
Feb 28, 2008 01:53 PM
78_ford_F150
May 16, 2004 02:46 PM
