Computer Chips & Tuners
sct programer ???
Old Sep 1, 2008 | 08:12 PM
Still Smoking's Avatar
Still Smoking
sct programer ???
What is the rev/mile for my 33/12.50/17 tires. And also my dad has a 01 f150 crewcab. If mine works out which so far it is. He wants to get one would be all 87 octane setting would you recomend the custom or pre programed tunes. He wants it for a little better mileage. 2 miles is all he is really looking for cause he knows he cant expect much more. He dont step on it he takes it easy so I dont think he should have a problem. We tow a boat and snowmobile trailer everyonce in awhile so the tow setting would be a must.
Old Sep 2, 2008 | 07:20 PM
dkf's Avatar
dkf
For the Rev per mile of your tires, go on the tire manufactuerers site and get the info. If that site doesn't have it look up the tire size specs of a BfGoodrich AT in the same size, I know they have the info.
Your dad won't see a 2mpg increase with a tuner on his truck regardless of tuner manufacturer.
Old Sep 3, 2008 | 04:16 PM
Still Smoking
Well im seeing a 2mpg increase in my truck and its the 5.4 3v so why wouldnt he the only difference is he dont have a 3v
Old Sep 4, 2008 | 03:01 PM
dkf's Avatar
dkf
A good tune for 87 actually fattens up the A/F ratio. An SCT 87 fuel economy tune for a 4.6l F-150 only made .3mpg better with the economy tune tested in Ford Performance Trucks mag. I find it super hard to believe your seeing a 2 mpg increase with 87, must be some other variable in there that caused it. Is your speedo, odometer and everthing spot on, especially after you switched to larger tires. From my experience with tunes on modulars you don't gain mpg on 87 and you won't gain hardly any power on 87 either, however there are other benefits to tuning. Some said they gained 2 mpg on a 93 tune, I still find it hard to believe,though higher octane usually has little to no ethanol in it. Just too many varibles, ethanol content, fuel quality, air temp, oxygenated vs non oxygenated fuel, load, terrain, wind restanse and etc.
I think a lot of it is the plecebo effect.
Old Sep 4, 2008 | 07:37 PM
Still Smoking
Well on the 87 economy tune I went 107 miles and filled it up just to see. It took me 6.3 gallons to fill up which equals 16.98 mpg so round up and its 17. I do all my mpg calculations by hand since I dont have a thing on my truck to tell me. My speedo is 5 mph fast but I reset the odo and pulled out my gps and reset the odo on that and it was dead on. So everything is on except the speedo. I tried to get the speedometer reset when I bought it cause it was off without the tires and they said there is nothing they can do cause its stock tires. Figured bigger tires would change it to.
Old Oct 26, 2008 | 08:36 AM
Johnny Langton's Avatar
Johnny Langton
I'll disagree with this statement. The 5.4L's can gain 2-3 mpg with a good tune-especially the VCT 3V's. Not everybody knows how to accomplish this,but some of us do.
JL
Old Oct 26, 2008 | 11:00 AM
FTE Ken's Avatar
FTE Ken
The tunes from SCT aren't that good out of the box. Some of them are downright horrible. SCT's F150 base files tells me they might spend more time with Mustangs than F150 programming and anyone who builds off them, are building tunes from a bad start. Lots of things that are more valid for Mustangs. A good F150 file needs to be written with the F150 needs in mind, and can accomplish things like better mileage and better power (and no, the power isnt increased by fattening up the a/f). The SCT shifting, better than stock but still horrible.
Special attention to how the transmission is dealt with (especially TC lockup strategy) alone can increase mileage. Careful who you choose to custom tune your vehicle, a lot of tooners out there claiming to be be tuners and all they do is take a less than stellar base file and make less than stellar changes (if any at all).
Old Nov 5, 2008 | 10:58 PM
Power_Hungry's Avatar
Power_Hungry
Former ******
To answer the first question, the estimated Rev/Mile on 33's is 610 (with a 4% tire squish).
As Johnny and Ken mentioned, 2+ MPG is absolutely possible and we have customers that regularly see those numbers. In fact, on our Expedition we've seen 4+ MPG (documented) on long highway trips and 2+ with local driving. It all in the tuning. Of course, as Johnny mentioned, I have a 2005 with a 5.4L VCT 3V which is significantly different than an 01 4.6L 2V. On those 1 to 1.5 MPG is fairly common. Oh, and I also have a 3.30 gear which really helps those highway numbers.
Ken, I agree with you on the SCT truck tuning. Like you, I believe they spend the lion's share of their time on Mustangs, GTs, and other more exotic vehicles and less on the F150s. If one was to go with an X-Cal, then either Troyer or Justin at VMP would certainly be the tuner of choice.
Good luck with your decisions.
timellis
Nov 21, 2011 09:54 PM
bama29fan
38
Dec 11, 2010 04:06 PM
Battman76
Jul 22, 2010 01:18 AM
osman
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Aug 7, 2005 07:01 AM
Skipped_link
Jul 15, 2004 01:01 PM
