1st time pulling since 6.0 trans cooler and exhaust.
Hey guys,
Saturday I went down to Morristown to pick up our backhoe. This was the first time I have pulled anything since adding my 6.0 trans cooler and 4" exhaust. I'm guestimating the backhoe and trailer weigh somewhere around 9,000 lbs. I was amazed at the trans temps and egt's. My trans temp never got over 165*. The highest that I could get the egt was 1000*. I averaged 70 mph at 2700-2800 rpms. Thanks guys for all your help.
I am happy with mine for sure and I dont even tow. the only time i got hot temps was going slow and it was 90 out. but once moving again. 200 was no longer.
I still reach hight temps on long grades even with my 4 MBRP, but I think that is the diablo at the 60 setting.
all in all I am happy with what I had done to my truck.
Let me ask a dumb question here. Is the 6.0 trans cooler and the early 99 7.3 trans cooler interchangeable? I have an early 99 and towing my 5'er sometimes my trans temp will be up in the neigborhood of 215-225 degrees on a 95-100 degree day. Other times it usually only gets to about 185-200 when it is only 70 or so outside. Mind you this is in stop and go traffic. After a while of cruising on the freeway at highway speed it will come back down to about 165 or so.
[quote=racincowboy;6506592]Let me ask a dumb question here. Is the 6.0 trans cooler and the early 99 7.3 trans cooler interchangeable?quote]
Yes here is some more info https://www.ford-trucks.com/forums/6...-write-up.html
