Which injectors?
Old Sep 3, 2008 | 02:31 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by strokin_it7.3
Alot of guys particularly on the other site, hate II's service and warranty (non-warranty). I havent had any experience with them, but alot of guys like casserly, and beans injectors, however bean gets his from casserly, d'oh. The next set i get will probably be casserlys.
How much cheaper are casserly's compared to Beans? Do you have a link for the casserlys?
Old Sep 3, 2008 | 02:54 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I dont know how much cheaper they are, but it's like cutting out the middle man, kind of like someone buying their product straight from your supplier instead of you, if that makes sense.
Ive done a little googleing and it looks as if he doesnt sell directly to the public in MOST cases, you gotta go through a vendor.. Not sure though.
Old Sep 3, 2008 | 02:58 PM
miller_feed
Thats why I asked, couldn't find anything either. I know about the middle man thing. I go through that all the time. People always asking me where I get a certain product, I tell them and they call the company. Then they come back and buy it from me. lol
Old Sep 4, 2008 | 12:32 AM
kupaa's Avatar
kupaa
Check these out Outlaw Diesel Performance :: Online Store only 820.00
Old Sep 4, 2008 | 07:16 AM
Tecman's Avatar
Tecman
Do you typically get better MPGs with single shots? Other than more power from a single shots, are there any other differences?
Old Sep 4, 2008 | 07:40 AM
mueckster's Avatar
mueckster
I have been researching this for a while now. From what I've asked about singles and splits, I have found that all recommend going to singles w/ single shot programming. This would give the best of fuel economy and power increases. Split shots would not yield any better fuel economy without increasing air intake, such as a bigger turbo. For those who are not heavily modded, the singles would give you more bang for your buck without spending alot for upgrades. Just my 2 cents worth.
Old Sep 4, 2008 | 08:26 AM
PowerstrokeJunkie
Theoretically, any comparable single shot injector to a split shot injector will give better power, and mileage. The method to produce the "split" shot used, is there is a small hole in the barrel of the oil side of the injector. As the intensifier piston passes over this hole it is uncovered, dumping the HPO right out into the valve covers. This delay of oil pressure pauses injection for a small time, which means the oil that was lost due to the split phase can be used in a single shot injector, there is no hole to dump oil, so single shots use about 30% less oil volume at the same pressure, which means that they can actually raise ICP, while improving mileage. After having single shots, split shots just sound ***** to me. Like when i was rolling up to the campfire the first night at Smokin, there was Jeremy, mike, brandon,and chris all standing around the camper and they made fun of how quiet and gay my truck sounded. The single shots make a powerstroke sound like it should. Ugh this Lorateb is strong...
Old Sep 4, 2008 | 08:38 AM
mueckster's Avatar
mueckster
When factoring the cost of big oil or new HPOP to get the full effect of split shots vs the cost of programming for the single shot tunes, you are still money ahead with the singles. From what I've heard, if there is a problem with your chip, and it is removed, you could still "limp along" with the stock programming without being completely shut down.
Old Sep 4, 2008 | 08:54 AM
Tecman's Avatar
Tecman
Well when it comes time, looks like im getting Single shots. I just wish injectors wernt so expensive! Hopefully winter will be good to me and dump snow on us regularly.
Old Sep 4, 2008 | 11:02 AM
white Buffalo's Avatar
white Buffalo
Just to add to what has already been said. I saw a 50 hp increase on the dyno after changing over to 175/146 single shots. About a 1 mpg gain, but I have a heavy foot. As Kris already said, the stock HPOP can maintain the ICP called for by the programs better than with split shots injectors. I installed the HPOP gauge before the injectors and I no longer get the - peak; then bleed off of ICP with the SES light going off - in the daily driver & tow programs. Maybe not so much in the extreme setting but I rarely go there. With that said I still do not set the SES light in the extreme setting.
Old Sep 4, 2008 | 11:06 AM
Tecman's Avatar
Tecman
Good to know, I can set off the SES light in 80E. I have the OA so unless it needs to get recalibrated its the ICP setting it off. Between the MPG gain and the efficiency beneifits it looks like single shots are a clear winner for me. Looks like its time to start saving!
Old Sep 4, 2008 | 11:10 AM
white Buffalo
check out www.totaldieselperformance.com also. He has remanned stage I inj for $850 and new for $1600. Here is the link:
http://www.totaldieselperformance.co...lts.asp?Cat=45
Old Sep 4, 2008 | 11:19 AM
  #28
miller_feed
Thanks for the link, Rich. That is a good price for the stage II injectors. Are they the same ones that Beans sells?
Old Sep 4, 2008 | 11:26 AM
  #29
kupaa's Avatar
kupaa
How much more will my egts rise with 175/146 ss with my current mods.And how much more hp will be added because i have pmr and want to keep it below 375hp.
Old Sep 4, 2008 | 11:33 AM
  #30
white Buffalo
Not sure Rick but I will PM you Ben's e-mail address. He knows more of the details.
No increase in EGT's, the fuel is atomized better since the ICP can be maintained better. Also, these injectors have the stock nozzles.
Very good for towing.
But, you might need to consider a turbo upgrade with your setup.
