60 amps
Old Oct 7, 2000 | 02:33 PM
gypsybill's Avatar
gypsybill
60 amps
Drove my truck to work the other day.. all is fine... go out to start it to go home... it starts and I get a really loud alternator belt squeal.. the ammeter pegs.. shut it off and restart, same thing happens... I check the belt.. it's tight.. well, I have to get home.. 10 miles so I go..
Squealing finally stops but ammeter stays pegged at 60 above idle. I get home without frying anything... get my trusty digital voltmeter, attach it to the battery at idle and I get 16.7 volts, off idle, I get 17.4 volts.. engine shut off, battery shows 13.2 volts... nothing smells burnt, no wiring toasted...
Engine is a '70 351W.. wiring is out of a '76 T-bird.. (where the original donor engine came from).. ignition system is ACCEL 300+ running thru a speedshop rebuilt recurved duraspark dist. Alternator and voltage reg are about 3 years old (Autozone specials)...
I suspect either the alternator or voltage reg..
suggestions before I pull them out for checking?
Bill in Mobile
'64 F100 Shortbox ('70 351W/'76 C4)
Old Oct 10, 2000 | 10:48 PM
jbhf250's Avatar
jbhf250
60 amps
I would be on track with you and have the alternator AND reg. checked and if you can just replace both
__JOHN__Õ¿ö
Member-
"Crusin North" Car Club
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://clubs.excite.com/72FORD-F-250
Old Oct 11, 2000 | 01:27 PM
Chuck P.'s Avatar
Chuck P.
60 amps
