Engine Dies When Hot
Old Aug 2, 2000 | 03:07 PM
joeservo's Avatar
joeservo
Old Oct 10, 2000 | 09:53 PM
block0's Avatar
block0
Hi,
I have a 1987 Ford Bronco with a 302 V8 engine. Last week the battery light came on steady, so I decided to check it out. I was driving the truck to the store to get some supplies, when all of a sudden the engine died. I tried starting it again, nothing. It wouldn't even crank over. I figured it was a dead battery, so I got a jump and got it running again. I got it home, and pulled the alternator. It was confirmed bad, so I bought a new one and put it in, and charged the battery. That solved the battery light problem. However, the next day, I tried starting my truck, and the starter relay just clicked. I figured ok, dead battery, so I jumped it, it started. I shut it off again and tried restarting, it cranked over like normal (fast) and started right up. I took it out later that day, and after driving for a while, the engine died again. This time, it would crank over very slowly, but it would not start. Almost like it had no spark. I waited until the engine cooled down, and then tried it, it cranked over with full power and started right up. Since then, I have not dared drive the truck, but I cannot figure out what's wrong. Could it be the starter relay? Ignition coil? Something else? Any help is appreciated.
Old Oct 10, 2000 | 10:44 PM
jbhf250's Avatar
jbhf250
I would just replace the battery... AND the cables also!! since you can jump start it, I would rule out the coil and the like... being bad.
__JOHN__Õ¿ö
Member-
"Crusin North" Car Club
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://clubs.excite.com/72FORD-F-250
Old Oct 10, 2000 | 11:43 PM
nitro94's Avatar
nitro94
Pay close attention to the battery cable connections. All 6 ends.
2000 XLT Flare Supercab Sport 5.4-Auto-355LS-Tow pkg-Bedrug-Xtang Tonneau
Old Oct 14, 2000 | 09:41 PM
block0's Avatar
block0
Hi,
Thanks for the replies. I checked the battery cables, and both the + and - off the battery needed replacing. The negative cable certainly is a pain to replace. But it was worth it, as the problem seems to have stopped. Although today the engine hesitated for a few seconds once while I was driving it, but that's probably a new problem. I also replaced the starter relay for good measure. Thanks again for the help.
-Randall
1987 Ford Bronco 5.0L
