6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
DTC trouble code help!!!
Old Aug 31, 2008 | 05:39 PM
Hester007's Avatar
Hester007
I am running an SCT tuner: getting the following codes
U0100
P2453
P2455
I would appreciate any help thanks
08' King Ranch
Old Aug 31, 2008 | 11:02 PM
PowerStrokeHD's Avatar
PowerStrokeHD
U0100 - Lost Communication With Electronic Control Module(ECM)/Powertrain Control Module (PCM)
Detailed Description...
This DTC is set when the PCM can not communicate with the transmission control module (TCM).
Possible causes...
Communication error
P2453 - Diesel Particulate Filter Pressure Sensor A Circuit Range/Performance
The powertrain control module (PCM) monitors the diesel particulate filter pressure sensor for offset and stuck signal value concerns. The test fails when the diesel particulate filter pressure sensor signal value at key ON, engine OFF is greater than 2.5 kPa (0.36 psi) or the key ON, engine running signal value changes less than 0.01 volt in 2 minutes.
Possible causes...
Corrosion or poor mating terminals and wiring
Leaks in the diesel particulate filter pressure sensor connecting hose
Damaged diesel particulate filter pressure sensor
P2455 - Diesel Particulate Filter Pressure Sensor A Circuit High
The powertrain control module (PCM) monitors the diesel particulate filter pressure sensor for a high voltage concern. The test fails when the sensor voltage is greater than 4.90 volts for greater than 15 seconds.
Possible causes...
DPF signal circuit open or short to voltage
SIGRTN circuit open
sasarrn
Mar 26, 2015 10:23 AM
weberr7
Jul 2, 2012 03:22 AM
rgn19
Jan 4, 2011 12:06 PM
cabo169
1983 - 2012 Ranger & B-Series
Apr 28, 2009 06:54 PM
jamillertriathlete
Modular V8 (4.6L, 5.4L)
Dec 6, 2002 11:28 AM
