Sponsored by: Kumho
pitman arm removal
Old Aug 31, 2008 | 04:22 PM
janedoe058's Avatar
janedoe058
pitman arm removal
Im having trouble getting the pitman arm off the knuckle .what is the right way ot get this off?
Old Aug 31, 2008 | 10:14 PM
77ford guy's Avatar
77ford guy
I just finished doing this on my truck. The best thing to do is heat it with acetylene, but be ready to buy a new dust boot (about 4$) I've already had them so bad that i cut a hole through the center of the threaded end with a torch, but this ruins the pitman arm so i dont recomend it. Also, put the nut on the end of the bolt and beat it with a hammer, the nut keeps you from destroying the threads. Good luck!
Old Aug 31, 2008 | 10:47 PM
quaddriver's Avatar
quaddriver
big-*** hammer? kidding.
got a pitman arm removing tool? (yes there is such a thing) you can rent one from many auto parts stores.
Hold a second. I reread your post. Pitmarm arm off the knuckle?
the pitman arm bolts onto a splined shaft at the steering box, and the other end is a regular tie-rod-ish end that goes into the drag link. Is that what you mean? Or removing a tie rod end from the steering knuckle?
(in any case my answer will involve a tool you can rent. or the big-*** hammer)
Old Sep 1, 2008 | 09:21 PM
rebocardo's Avatar
rebocardo
Year, Make (Ford I assume), model, 4x4?
Do you mean the tie rod? Usually a pickle fork or a big hammer, I usually use a pickle fork with an impact hammer.
Old Sep 4, 2008 | 11:45 AM
Lazy K's Avatar
Lazy K
If it is the tie rod end then a cheap pickle fork tool gets my vote.
