Hello,
I have a 1999 F350SD 7.3 4x4 Crewcab Lariat LB. I recently experienced a headlight problem. Intially the headlights would not come on. I had to jiggle the turn signal/hi-lo beam lever. Then once when I turned the Headlights on they were in lo beam position but the hi beams came on for about 5 minutes. They would not change by moving the lever. Finally they went to lo by itself. Now the come on when turned on, but the right lamp is very weak. Any similar experiences or thoughts?
Thank you,
Jimmy
