lights
Old Nov 15, 2000 | 10:51 PM
lindell's Avatar
lindell
lights
just bought a 1994 f350 when i turn on the head
lights cab&side lights will not come on till
i move switch in&out just replaced tag&one cab light bulb any help or advice
thanxs
Old Nov 16, 2000 | 03:02 PM
probertstx's Avatar
probertstx
lights
I had a real similar sounding problem to this in my 88 F150. Parking lights come on as normal at the first detent, headlights come on as normal at the second detent. My problem was that when the headlights came on, all the rest went off!
Tried replacing the switch, but it turned out I had a fuse that had fallen out. The missing fuse wasn't listed in the Haynes book, but was shown on the fuse box diagram on the cover.
I guess that shows you should read everything before assuming you broke something!
Old Nov 17, 2000 | 07:40 PM
lazer's Avatar
lazer
lights
had this same problem on my 94 super duty. I had to replace the switch twice what i didn't notice the first time was on the back of the wiring harness the plug was melted. Fortunately ford sells a repair plug with wire leads on it have'nt had a problem since
good luck
Old Nov 19, 2000 | 07:41 PM
jbhf250's Avatar
jbhf250
lights
