Power cuts out
Old Nov 6, 2000 | 11:46 AM
scoutsmotorsports's Avatar
scoutsmotorsports
Power cuts out
My girlfriend has a '83 with a 2.9L V6. First off the battery keeps bein' drained when it sits over night (a lot of jump startin' and chargin' on the charger). Any suggestions why it's doin this?
Second when the truck is hits a bump all hte power temporarly dies out then comes back on after a second or two. Any suggestions why? How to check for a short? Any help would be appreciated.
Old Nov 14, 2000 | 08:56 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Power cuts out
[font size="1" color="#FF0000"]LAST EDITED ON 14-Nov-00 AT 10:00 PM (EST)[/font][p]Scout, is the battery loose and hitting the hood when you go over a bump? As to the short, they're hard to find. It's probably not a short, just a small drain from something staying on. Take an ammeter and run from the neg batt cable to the post, this will show you the drain. Then it's a matter of pulling fuses until you find the circuit with the drain. (First off, check the courtesy lights above sunvisors if you have them.)
Good luck.
"Nothing lasts forever except natural stone and old Ford trucks." (Willie Nelson)
Old Nov 21, 2000 | 09:30 PM
trouble's Avatar
trouble
Power cuts out
Scout, dont forget about your grounds, they cause peopl alot of money and time.Ive had trucks in shop that i have pulled all the fuses and still have a be hot, come to find out its a ground problem 90% of the time .
Old Nov 29, 2000 | 11:13 AM
jbhf250's Avatar
jbhf250
Power cuts out
pm042070
Aug 18, 2014 09:40 PM
Cuter
Apr 3, 2014 06:02 AM
Olson12345
May 31, 2013 04:21 AM
Bound UP Binder
New Member Introductions
May 2, 2008 06:20 PM
Ranger88
4 Cylinder Engines
Dec 1, 2005 01:30 PM
