Problem Found
Old Aug 31, 2008 | 06:48 AM
big1's Avatar
big1
Problem Found
Two week's ago I posed a question to the member's. I attempted to locate it, without any luck. Oh Well
The question was about locating a leakage problem in a C6 transmission.
I tried everything I could think of without luck.
The last time I pulled it out I noticed that the pump bolt's weren't seated. I thought that I had forgotten to torque them. NOPE.
I discovered that the bolt's were bottoming out in the case before the pump was seated. I have never came up on this before and wanted to let the member's know of my discovery.
This transmission came from a running driving truck!!!
Old Aug 31, 2008 | 08:30 AM
Tedybear's Avatar
Tedybear
So it was the wrong bolts installed? Forgotten washers?
Odd one.
S-
Old Aug 31, 2008 | 02:43 PM
big1's Avatar
big1
I really don't see how they could be the wrong one's. They were the one's that were in the transmission when I tore it down. The pump is the only plase in a C6 that use's that lenghth of 5/16 bolt.
Old Aug 31, 2008 | 03:49 PM
Tedybear's Avatar
Tedybear
Well then, ya got me scratchin' the noggin. Unless somehow they had washers that extended the heads of the bolts out far enough for them to seat the pump, and still have enough room for correct torque?
**shrugs** Not sure? I've never encountered this type of issue with a teardown/rebuild.
S-
Old Sep 1, 2008 | 07:49 AM
big1's Avatar
big1
I'm nearly 60yr's old. I've been building transmission's since the age of 13 and I've never came upon this before.
Old Sep 1, 2008 | 10:14 AM
80F100man's Avatar
80F100man
So, did you use more washers or what to get it to seal?? Just curious.....
Old Sep 1, 2008 | 12:21 PM
big1's Avatar
big1
I didn't want to chance having to pull it out yet again, so I went to the hardware store and bought long threaded grade 8 bolt's. I cut the head's off, chased the thread's, screwed them into the case,reinstalled the pump, and torqued the hardened nut's to spec's. The next morning I torqued them again to make sure and put the darn transmission back in. Work's great.
But DAMN what a headache it was getting there.
Menghi08LT
Mar 22, 2018 05:25 AM
Kingfisher591
Sep 26, 2012 08:58 PM
bailegb
Flathead V8 & Flathead 6
Mar 27, 2010 09:26 AM
dffdixie
1983 - 2012 Ranger & B-Series
19
Sep 11, 2009 11:02 AM
wa97f250
Feb 3, 2005 07:58 AM
