fuel selector for front tank...
Old Aug 31, 2008 | 02:16 AM
mercrs's Avatar
mercrs
I have a 89 F250 w/460 C6
my front tank doesn't work,I think I have a Shuttle selector?
chiltons is kinda vague is there any info on troubleshooting these problems
or could it be a fuelpump?
would a scan tell me?
Thanks
Old Aug 31, 2008 | 02:31 AM
mercrs's Avatar
mercrs
did more research on this site can anybody tell me the right part # for them?
Old Aug 31, 2008 | 09:41 AM
quaddriver's Avatar
quaddriver
part# for what part?
In mid/late 89 ford switched to 2 hi pressure pumps in the tanks and no boost pump/reservoir on the frame rails. Can you peek underneath the cab, just aft of the ABS valve and see if that hardware is there?
Old Aug 31, 2008 | 11:17 AM
subford's Avatar
subford
Selector valve assy, p/n F1UZ-9B263-B
It could be the in-tank pump.
I do not think so.
Old Aug 31, 2008 | 06:18 PM
SailorNorm's Avatar
SailorNorm
Me to
My 89 F150 just started acting up. I wonder if it's the same problem.
Rear tank selected runs fine, switch to front, guage shows full (and it is) runs about 1 min then quits. Switch back to the rear and it starts.
So is it the selector or the fuel pump, and how difficult are they to change?
jrd
Old Aug 31, 2008 | 07:14 PM
subford's Avatar
subford
jrd
The selector valve is easy to change if the tanks are not full.
The in-tank pump is a lot harder, you have to drop the tank or take the bed off then it is a mater of getting the pump ring off and back on, this is the part I do not like.
You need to find out first what the problem is. Is it electrical, the pump in the tank or is it the selector valve.
First I would have someone turn on the key while you lessen at the tank.
The pump should run for one second. If it does this then take the pressure hose off coming from the tank at the selector valve. Repeat this operation and see if you get fuel from the hose. If you do not hear it run or you get no fuel then it would be the pump in the tank or an electrical problem.
If you get fuel then you will have to find out how much pressure you have, it should be about 5 psi or less. You can put your fuel pressure/vacuum gauge on the end of the line to see what you have.
Never put more than 5-psi air pressure on the selector valve to test it or you can blow the diaphragm. You should hear the selector valve snap from one tank selection to the other when you put the air on the nipples on the valve where you took the pressure hoses off.
If the pump did not run at all then try to re-seat the plug on top of the tank and try it again. If still no go check for power with a test light at the plug for the tank. If the pump wire is hot to the ground pin of the plug then you have a bad pump. You should not use a DVM here as you need to load this circuit.
KHflatbed
Oct 12, 2016 09:58 PM
Jonnys.1991
Apr 11, 2016 08:18 PM
Mikey bist
Dec 16, 2015 03:27 PM
motman
Jun 12, 2013 09:48 AM
88 250
Oct 6, 2010 07:17 PM
