E Brake Question
Old Aug 30, 2008 | 06:05 PM
RH F-350's Avatar
RH F-350
E Brake Question
I have a 2004 E-250 with discs on rear e brake goes to floor wont hold any suggestions? Thanks.
Old Aug 30, 2008 | 07:41 PM
JoSHN's Avatar
JoSHN
Check the cable at the rear brakes to see if it is loose.
If there is any play in the cable when the brake is pressed in, tighten it.
Also, check to see if there is any movement of the cable at all.
If there is no movement between pressing the pedal down, or releasing it, check the cable on the pedal itself.
Old Aug 31, 2008 | 04:02 PM
RH F-350's Avatar
RH F-350
Yea i checked all the above everything looks and feels right. Do you know if it has an adjustment near or in the back wheels? Thanks.
Old Aug 31, 2008 | 04:19 PM
JoSHN's Avatar
JoSHN
I really don't know too much about the E series, so I don't want to go spewing out wrong info.
I'm going to let someone else who might have more knowledge of this give out the right info.
Good luck, and sorry i couldn't help too much.
Old Sep 1, 2008 | 08:22 AM
FordTechnician's Avatar
FordTechnician
Did the pedal go to the floor suddenly or just over time? If it went suddenly, you might have seperation of the parking brake shoes. When they get alot of use, sometimes the linings seperate from the shoes. You would need to remove the rotors to replace them. And, yes, they do have an adjuster.
Old Sep 1, 2008 | 08:11 PM
RH F-350's Avatar
RH F-350
Thanks JoSHN and Ford Technician for your help. The pedal went to the floor over time and not suddenly.So can i just adjust them?
Old Sep 2, 2008 | 01:23 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
yes, there is a screw thingy inside the brake drum. you initially set tension with this, and it self adjusts over time every time you use the e-brake (as needed).
you need to pull the rear disc/drum assembly off and take a look.
post up pictures if you can
