Mystery Noise Found!!!!
Old Aug 29, 2008 | 12:55 PM
greagin's Avatar
greagin
i am so happy to report that my mystery noise has been found after many maddening searches!! it seems that at certain times under certain conditions at various geometries, the cold side intake tube for the CAC was rubbing against the airbox that sits underneath the location of the map senor area. This was sennding a rattling and vibration noise thru the firewall and into the cab that was very difficult to trace!! as it was not consistent as to when it would happen!! Problem has now been solved and i must thank Brandon for listening to me whine through several phonecalls and helping point me in the right direction!!
Old Aug 29, 2008 | 01:40 PM
Ponyboychris's Avatar
Ponyboychris
thanks for following up on the solution to your problem. That helps a bunch. I hate not knowing how people's problems are resolved.
Reps to Brandon - if I can ever do them again...
Old Aug 29, 2008 | 03:21 PM
danskool's Avatar
danskool
Go Bills !
Good work. I had also a noise that was hard to track down. Found it was the pipe tapping against the power steering bolt. It ever so slightly cracked the pipe and that was when i did the foil delete.
Rick_Fury
45
Jun 1, 2011 07:03 AM
Rick_Fury
15
Feb 20, 2011 07:43 PM
markfes
Jun 25, 2010 08:23 AM
Tdean1
2004 - 2008 F150
23
Jul 13, 2008 08:27 PM
TopoGeorge
May 14, 2008 10:17 PM
