Brake Fluid Replacement
Old Aug 29, 2008 | 09:00 AM
pminne's Avatar
pminne
Rocky Mountain High
Anyone know when the brake fluid should be flushed and replaced in an '03 Explorer? Pads replacement seems like the obvious time, but if it isn't necessary until 100k or so is there a compelling reason especially if there are no brake problems other than needing new pads? Thanks!
Old Aug 29, 2008 | 10:18 AM
Steina's Avatar
Steina
CO River Rat
My guess would be to check the master cylinder. If the fluid looks clear and clean, OK; if it's dark then consider replacement.
Steve
Old Aug 30, 2008 | 09:42 AM
srercrcr's Avatar
srercrcr
If it's dark, you're too late. I have done it every few years, find a shop that will do it cheap. They have the equipment to do it in less than half an hour.
I have gone to an alternative preventive routine. Once a year I suck the fluid out of the resevoir with a turkey baster and add fresh. It seems to do good, not perfect but good. I also do the power steering fluid too.
Old Aug 30, 2008 | 05:49 PM
steve(ill)'s Avatar
steve(ill)
a 2003 in normall driving should not need the brake fluid changed. it dont hurt to flush out a little and i do somethink like srercrcr, but in reality, it should go 8-10 years.
Old Sep 1, 2008 | 09:57 AM
MisterCMK's Avatar
MisterCMK
I flush the brake fluid in my vehicles every couple of years. New brake fluid makes a big difference in pedal feel as brake fluid is hydroscopic meaning that it absorbs water. When you get fresh clean fluid in there the brakes feel much better.
Old Sep 1, 2008 | 12:45 PM
srercrcr's Avatar
srercrcr
....and less chance of phenolic caliper pistons hanging up. Keep it clean!
Old Sep 2, 2008 | 12:58 AM
r6bikerdave's Avatar
r6bikerdave
yes please dont go 8 or 10 years!! brake fluid absorbs moisture and needs to be flushed every 2 to 3 years
