Front End ?'s
Old Aug 28, 2008 | 05:42 PM
tbuford's Avatar
tbuford
Question Front End ?'s
Okay guys here we go...had the leveling kit installed on my v10 4x4 lim last week...a few days later noticed a "knock" when braking...took it to the stealership to have the oil changed and had them take a look to see what was going on. It had a little bump on accel and braking that I wanted them to check as well....so after the oil change, the tech came to me like a doc letting you know you have 6 mos to live....he said...needs ball joints (L side)...u-joints...and a pinion seal replaced. Funny to me that the guy installing the leveling kit noticed none of the above items...
I need input on symptoms of each problem, estimated repair costs, and you thoughts in general....as always...all input is appreciated...thanks
Old Aug 28, 2008 | 07:54 PM
Monsta's Avatar
Monsta
Sit. Stay.
First thing that comes to my mind on the issue of "a little bump on accel and braking" is the rear driveshaft's slip joint needing lubed.
Which pinion seal was he talking about?
Old Aug 28, 2008 | 10:47 PM
tbuford's Avatar
tbuford
I will pull the estimate out of the glove box in the am and post which one...I know that we really set ourself up by going to the stealership but I just hate that I went for the oil change and now I'm looking at about $900 in repairs...should have known asking "can you tell me where this noise is coming from?"....oh well....I will post back in the am...thanks
Old Aug 29, 2008 | 05:41 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Ken,
I have that same thing, a slight bump when I stop and start off again. Should I be looking for a greaseable fitting, or do I just have to push grease in? And the 1 million dollar question, do you have a picture of it?
Thanks
Old Aug 29, 2008 | 02:18 PM
Monsta's Avatar
Monsta
Sit. Stay.
There is no grease fitting. You have to drop the driveshaft and apply grease. Here's the how-to. Stan's page shows a carrier bearing. We don't have a carrier bearing so don't worry when it doesn't look exactly alike You should get the idea. This is a driveway fix that should take about an hour if you do it methodically and have never done it before.
Slip joint regreasing
Old Aug 29, 2008 | 10:57 PM
FordTruckGirl77's Avatar
FordTruckGirl77
And put the blocks under the tires before disconnecting the driveshaft!
We did ours over a month ago and no clunk since!!!
Old Aug 29, 2008 | 10:58 PM
sddesigns's Avatar
sddesigns
FTE Emeritus
Block wheels...good, that could have been messy..LOL Considering my garage is the driveway in the picture, just enough pitch towards neighbors house, after it ran my a$$ over...
Old Aug 30, 2008 | 12:19 AM
Swarn2racing's Avatar
Swarn2racing
Ball joints will make a "knock" when braking as well. Usually just as you apply the brakes you will hear it.
shaneinga
Apr 27, 2012 02:10 PM
Gotitcheap90
Sep 7, 2010 11:06 PM
scooter81
Apr 28, 2010 02:58 PM
F250_
19
Mar 9, 2009 08:57 PM
