Front Brake Rotors
Old Aug 28, 2008 | 03:21 PM
Polkster's Avatar
Polkster
Front Brake Rotors
I know i've seen it on forum before, i just wanted some fresh advice, thanks in advace for all your info.
Got 99 F450 got the wobble in front end when braking to a stop. Rotors are warped and can't be turned??
I saw on forum what kind and where to buy front and or rear rotors that will not warp like the factory rotors will.
What kind and where to buy rotors and brake pads that won't warp in future?
THANKS AGAIN for your input.
Old Aug 28, 2008 | 03:55 PM
DieselCamper01's Avatar
DieselCamper01
I put cryoed Powerslots on the front of mine with Hawk pads. I have been happy so far.
Turned rotors do not usually last long.
Old Aug 28, 2008 | 04:03 PM
jhand124's Avatar
jhand124
I think you are refering to cryoed power slots or power stops. All rotors will get messed up if you don't break them in properly
Old Aug 28, 2008 | 05:25 PM
zx250's Avatar
zx250
Of the next Riffraff East
Your rotors can be turned and the brake shops will tell you that they will work fine,,, WRONG! They were not heavy duty enough to start with and turning them down only makes them thinner and weaker. Several good rotors out there, with Power Slots being a favorite around here. The Cryos are supposed to resist warping even more. Took all the wobble out of mine.
Old Aug 28, 2008 | 07:53 PM
crazymut's Avatar
crazymut
I went with Power Slot cryos and Hawk pads. No more wobble going on about one year service now. Great investment.
Old Aug 28, 2008 | 07:55 PM
camodown's Avatar
camodown
I ended up getting Frozen Rotors (Diversified Cryogenics) and they have worked great so far. Still have the crosshatching visible, did the brakes in May. I got new front calipers, front and rear rotors, front and rear pads, and the total bill was <$1,000. My only complaint... an occasional squeek (normal), and a bit more dusting that I would have liked, but they are commercial pads and bit harder the hotter it gets...haven't faded them out... As said above, bed the pads in properly when you get new ones, and if you stop hard from a high speed, roll a little bit if you can, don't let the pads stop on the rotor, glide to a stop. Warped rotors actually arent the metal warped but rather inconsistent material transfer (pads) when the temps get too high. This leaves 'spots' of pad material on the rotor making the overall thickness inconsistent, leading to shuddering when braking.
