Bronco II Ford Bronco II
Rear bumper options...
Old Aug 28, 2008 | 03:19 PM
jackofalltrades's Avatar
jackofalltrades
My son's BII has an aftermarket rear tube bumper. It needs to be replaced. Got any ideas? I could weld something up, but I think he's looking for something with that stock look.
He wants one size larger diameter tires, (since we don't want to play with gear ratios right now), a 2" inch front lift (Probably just a poly bushing set under the stock springs), and a 1" leveling block in the rear. That, with a stock rear bumper that's quite tucked to the frame like the front bumber is should make the lil Bronco look very nice and function quite well in suburban mud and snow. He's not going to be thrashing this thing off road.
So... Rear bumper options that have worked for you? Maybe something with an integrated tow reciever?
-Steve
Old Aug 28, 2008 | 03:58 PM
michigan66's Avatar
michigan66
LMC Truck has replacement bumpers. Take a look at their on-line catalog to see if they have something that would be useful for you.
Old Aug 28, 2008 | 08:03 PM
rebocardo's Avatar
rebocardo
You could put on a step and tow bumper. My 1990 has one. I do not have a Ranger to compare, but, I am willing to bet it is a bolt on from a Ranger to Bronco II.
Old Aug 29, 2008 | 04:48 PM
80351's Avatar
80351
Heres my 90 with 2.5 lift front and rear,
and 31 BFG AT's.
front lift was done with the spacers. the rear was done with blocks
until I found out they had cracked in half so it is now repacked Explorer
springs.
Had 235/75R 15s on it when I got it and no lift.
Also has stock rear bumper and a Reese hitch.
I also purchased a book, Power Pro Series...
How to Build and modify Ford 60 degree V-6 Engines
(Motorbooks International) Sven Pruett
69supercj
Feb 21, 2015 03:06 PM
whiteisright
Nov 3, 2011 04:52 PM
Aune163rd
52
Jul 19, 2011 03:13 AM
texcan
Mar 22, 2006 03:02 PM
