New troubles
Old Aug 28, 2008 | 10:25 AM
Culvert's Avatar
Culvert
New troubles
I changed the oil out this past wknd. Used Motorcraft filter, 5-40 Chevron DELO 400 oil, and drained the fuel filter.
Cycled the key on/off several times to refill fuel. Long cranking times and very rough idle with tonnes of black smoke. Figured that was the system getting oil back into the injectors.
Drove around that day fine. Let the truck sit for 2 days and I tried to fire her up last night and took me 10min of cranking to get it to start. Just cranking & puking out black smoke but no start.
Finally got it started and sounded like it was on 1/2 the cyl and lots of black smoke. 1-2min of lumpy idling and then it smoothed out and ran fine for my trip into town. Started fine at all my stops in town.
Heading out of town this wknd with the travel trailer and would like to know what is going on with my truck.
Why would I be having so many issues after just an oil change? Is there anything I can check?? There is no DTC at this time.
Old Aug 28, 2008 | 10:32 AM
UGA33's Avatar
UGA33
Drained, meaning just the plug or was the HFCM cap pulled off? The black smoke issue sounds like EGR valve issues
Old Aug 28, 2008 | 11:22 AM
Culvert's Avatar
Culvert
Just pulled the plug. Let it drain for a few secs then reinstalled. never pulled the cap off completely to check the fuel filter.
Old Aug 28, 2008 | 12:39 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Sounds to me like you had air in the fuel system....once you worked all the air out, it was okay. How was it today?
Old Aug 28, 2008 | 12:42 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
"Cycled the key on/off several times to refill fuel"
You say you did this - for how long did you leave the key in the ON position before you recycled it again? You should leave the key in the ON position for about a minute each time, then recycle once or twice to refill the system with fuel and displace the air.
Old Aug 28, 2008 | 12:54 PM
Culvert's Avatar
Culvert
The problem I have is that I changed the oil and drained fuel on Sunday. Fired the truck up.. rough idle/black smoke. then cleaned itself out. Drove it around.
Parked for 2 days and then even harder time to start. At least 10 min of cranking and it just chugged and puked black smoke. Fianally got it to fire up and it was another 1-2min of rough idle/black smoke. Drove around town again.
So I will see what it does for starting when I get home tonight. I think something is loosing press when it sits for long periods.
Old Sep 2, 2008 | 07:01 PM
Culvert's Avatar
Culvert
Well of course the truck dies when I need it the most! Went out camping this wknd and hauling the 28' TT. Truck was still hard to start but once going ran fine. Went to come home Mon and the truck wont start up. Cranks over and dumps black smoke but no start. Draine dthe batteries trying to start so even tried boosting with another diesel, both batteries hooked to jumpercables. Cranked till it couldnt crank anymore
Towed to the dealer and left trailer at the site. Now its a 2wk wait till they can look at the truck.
Will update once I know more.
sackedbysapp
Jan 27, 2015 10:23 AM
Chase35
Feb 10, 2014 10:37 PM
whitesdford
16
Sep 27, 2009 11:03 AM
spotsjeep
Oct 12, 2008 07:40 PM
wilsonk1414
Jun 14, 2006 10:19 AM
