94' 4.9l Egr
Old Aug 27, 2008 | 06:22 PM
jcool460's Avatar
jcool460
94' 4.9l Egr
So, i just bought a 94' reg cab f150 4.9l doing some work to it.
I have replaced oil pan, and valve cover, including all new gaskets.
bolted down the upper plenum realized i had a vacuum leak because of the high rev.
Anyway, i went to re-tighten the bolts on the intake when i heard a loud snap as the lower intake broke, (vacuum line caught between upper and lower intake)
I am in the process of removing the lower intake. Injectors, vacuum lines, injector rail have all been removed as well as all the bolts that mount the intake to the engine. Although i cant seem to get past the egr valve it happens to be conveniently placed through the center of the intake.
My guess is that the heat of the exhaust will make removing it a challenge.
Any help will be appreciated.
Old Aug 27, 2008 | 09:39 PM
andym's Avatar
andym
Yeah, that bolt gets stuck on there really good. I think I crawled under the truck and got to it from there. My state isn't in the rust belt, so if you live there, be prepared to use lots of penetrating oil, heat, and cheater bars.
Old Aug 27, 2008 | 11:55 PM
optikal illushun's Avatar
optikal illushun
good luck with that. that EGR likes to rust out and break.
why are u removing the lower intake? when i did that i just slide the lower outta the way while the EGR was still intake on the manifold.
Old Aug 28, 2008 | 12:17 AM
jcool460's Avatar
jcool460
the lower intake is broken, i could try jb weld it but id rather change it out.
i took the pass. front tire off and tried to get at the egr through the fender well, but i guess i have to take off the fender well as well haha.
i was trying to get the egr off up by where it connects to the intake but im afraid ill bend the pipe. i have two cans of pb blaster dont worry about that. i may put a cheater bar on my cresent wrench and go to town. a torch would be nice but maybe not that close to the feed and return lines.
but i dont quite under stand what you mean "optikal illushun"
Old Aug 28, 2008 | 12:20 AM
optikal illushun
i just moved the lower on the EGR line but i guess u cant do that.
put a shield over the fuel lines and use a propane torch. after its hot use some ATF in a dropper and drip it on the threads. that usually works to get rusted parts loose.
Old Aug 28, 2008 | 12:27 AM
jcool460's Avatar
jcool460
transmission fluid? that works? i've never heard that b4,
i need a torch first and some atf fluid.
Old Aug 28, 2008 | 09:49 AM
jcool460's Avatar
jcool460
you mean you got the intake to come off without taking the egr off?
Old Aug 28, 2008 | 04:14 PM
jcool460's Avatar
jcool460
seems almost frozen in place, it may be easier to take the egr off at the exhaust manifold, but this is really frustrating i wish i had a torch.
Old Aug 29, 2008 | 06:33 PM
jcool460's Avatar
jcool460
i think i got it,
i am going to cut the old egr pipe off and get a new one along with a new lower intake.
but i was wondering if there was anyway to get some extra power out of these old 4.9l's i have read about switching the old 12psi injectors out with 19psi,
where would i find 19psi injectors for cheap? does ford use them on other models that i could use on my 4.9l?
HEpTJJ
Sep 11, 2013 10:58 PM
herb76
1997 - 2003 F150
Mar 31, 2013 08:52 AM
jimzettle
Oct 3, 2003 12:19 PM
