Anymore mods?
Old Aug 27, 2008 | 05:26 PM
Farmboypowerstroke's Avatar
Farmboypowerstroke
Anymore mods?
I happen to find $200 laying around!!! Is there any mods I can get for that?? that would gain me some hp???
Old Aug 27, 2008 | 05:28 PM
Mike Norwood's Avatar
Mike Norwood
Yeah, it's called the friendship mod. Send the $200 to me and I will be your friend.
Old Aug 27, 2008 | 05:32 PM
deereman4020's Avatar
deereman4020
I know you could give me the $200 so i can do some mods on my truck. Or you could save up for more expensive mods.
Old Aug 27, 2008 | 05:36 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Go fill up your tank.
Old Aug 27, 2008 | 06:06 PM
ron's power stroke's Avatar
ron's power stroke
1999.5 Ford F-350. Reg cab 4x4
Built tranny torq converter tranny cooler
AFE stage 1 magnum force intake with torque booster tube Proguard 7 filter
dualexhaust5 inch tips
Foil Delete
ISSPRO gauges
10k
AIH
CCV
Zoodad
ITP Boost Fooler
Tony Wildman
Turbonetics BB Turbo
Rims
203 thermostat
coolant filter
to come
then put the rest in your fuel tank...
white Buffalo's Avatar
white Buffalo
Get a scangauge if you don't already have a diagnostic tool:
Scan Gauge
Old Aug 27, 2008 | 06:09 PM
ron's power stroke
Scan Gauge
how much for them???
these are 269.
Terminator Engineering
Old Aug 27, 2008 | 06:26 PM
Farmboypowerstroke
Foil Delete
ISSPRO gauges
10k
AIH
CCV
Zoodad
ITP Boost Fooler
Tony Wildman
Rims
203 thermostat
coolant filter
to come
There i fixed it, i haven't updated my sig in a while, I got the coolant filter on
Old Aug 27, 2008 | 06:27 PM
white Buffalo
Ron,
Aeroforce is where he gets them from. He's one of the dealers.
Old Aug 27, 2008 | 06:32 PM
ron's power stroke
thats good...with the mod's you already got..the trans could use a filter to..
Ron,
learn something new every day...thanks Rich...
Old Aug 27, 2008 | 06:46 PM
Chuck U&R's Avatar
Chuck U&R
Trans filter ???
I did a search about trans filters and the impression I got was that using one would (could) add unnecessary back pressure and interfere with a valve body and or a tuner.
I like the idea of running all the filters possible but if there's a conflict ?????
Old Aug 27, 2008 | 06:53 PM
ron's power stroke
you need to look around..
http://www.dieselsite.com/index.asp?...ROD&ProdID=761
Our unit has a bypass valve in the housing as an added safety feature. This internal bypass valve in the housing is set at 25 psi to allow some fluid to bypass the filter should the filter become nominally dirty. In addition, if the filter becomes plugged, our unit will go into complete bypass mode and allow the full volume of fluid flow to bypass the filter and insure that your transmission always has returning fluid for lubrication. This full bypass condition will cause the overdrive light to flash due to high output pressure. This is a normal warning light. The PCM thinks that the transmission has a restriction somewhere in the fluid line and is letting the operator know.The higher pressure is caused from the resistance of the bypass valve spring. So, even though you have full fluid flow it is under higher pressure and the sensors that monitor line pressure in your transmission will detect the higher pressure. Simply change your filter and the light will go out. There is no risk of burning up a transmission from a dirty filter when you use our kit. With normal routine oil and filter changes and a properly operating transmission the full bypass mode will never occur.
Farmboypowerstroke
Good point i want to no more about this. Never mind, Ron beat me to it
Old Aug 28, 2008 | 06:08 AM
Chuck U&R's Avatar
Chuck U&R
So I'm good running your trans filter with an aftermarket valve body, cooler and DP Tuner ?
Trying to add some strength to that weak link.
