6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Fuel Capacity
Old Aug 27, 2008 | 04:56 PM
cHiLi 11's Avatar
cHiLi 11
Fuel Capacity
Ok so I cant seem to get a straight answer from any dealer. I want to know what the fuel capacity is in my 08 F250 4x4 CC standard bed 6.4L diesel.
I have been told its a 30 gallon tank and on a long bed is 33 gallon. Today I ran the sucker as low as I could go milking it to its last drop. It finally started to give a little resistance and I immediately filled the tank. I was only able to fill just over 27 gallons. Any help would be great!
Nick
Old Aug 27, 2008 | 05:02 PM
rev_man's Avatar
rev_man
My 08 CC long bed is 38 gallons Not sure on the short bed.
Edit: Just looked on Ford's website the short bed is 30.5
Ford Trucks: Super Duty 2008 Cargo Box & Exterior Dimensions. | Ford Vehicles
Old Aug 27, 2008 | 05:09 PM
B-52's Avatar
B-52
The most I have gotten into my long bed is 36 but I am sure there is 2 more in there. Not sure on the short beds 28-30 sounds about right. I would say at 27 you are with in a gallon or two of being to their mark.
The 08's defintely don't seem to fill the entire tank based on when tells you that you are empty???
Old Aug 27, 2008 | 05:30 PM
naseflorio's Avatar
naseflorio
Your tank should be 30.5 gallons. Your miles to empty warning is not accurate. They probably do this so you will not run it out of fuel.
Old Aug 27, 2008 | 07:43 PM
Carl Lassiter's Avatar
Carl Lassiter
Bingo. Running a gasser dry is fine (from an engineering standpoint) but do it in a diesel and it's big $$
Old Aug 27, 2008 | 08:10 PM
skl's Avatar
skl
Mine used to be 30 gallon- got a Titan 52 gallon now and couldn't be happier. The range is nearly doubled! With the old tank I once ran it to where the computer said 0 miles to empty- I didn't do it on purpose but IIRC it took about 28 gallons to fill it. Used to take forever to get that last gallon in but when I had that stupid little OEM tank I wanted it full to the brim...
Old Aug 27, 2008 | 08:21 PM
k_tort2002's Avatar
k_tort2002
I just filled up today on the way home and put in 29.8 and I was about as close to empty as empty can get.
I have an 08 CC F250 King Ranch.
Old Aug 27, 2008 | 08:29 PM
Serg450's Avatar
Serg450
I have a transfer Flow 60gal Tank. I love it man. I just seemed to always be filling the 38gal I had in it.
Jimmy63's Avatar
Jimmy63
Remember that diesel foams quite a bit as you are filling. As you approach the top of the tank, click the flow down a notch to slow the flow. After it kicks, let the foam settle and continue to slow fill, stopping to let the foam settle intermittently. You will be amazed at how much more fuel you can add. It takes a little time to get it completely full.
Old Aug 28, 2008 | 07:11 AM
senix's Avatar
senix
I have a short bed crew cab PSD, tanks holds 30 gal, message center comes on at 22 gals saying filler er up. Long beds take 38. These numbers would be bone dry.
Old Aug 28, 2008 | 12:02 PM
Carl Lassiter
60gal tank is an awesome addition. Factory or after market?
Old Aug 28, 2008 | 12:39 PM
Serg450's Avatar
Serg450
After market. The company is called, Transfer Flow. In Corona California.
It uses all the factory hardware, it took 2 hours to do the swap in my garage.
Old Aug 28, 2008 | 12:56 PM
Carl Lassiter
Great stuff, did you install yourself? There must be a lot of space by the wheel wells in duallies.
Old Aug 28, 2008 | 01:01 PM
Serg450's Avatar
Serg450
yes I did it myself. Me and a buddy. It's just longer than the factory one,and it takes up all the in used room around were the stock tank sat.
Old Aug 28, 2008 | 01:02 PM
rmosso1's Avatar
rmosso1
From the Ford web site with an asterik to the 30.5 which equates to "new for this model year."
Fuel Tank
38 Gallon mid ship – 8' box ● ● ● ●
30.5 Gallon mid ship – 6 ¾' box��
if I remember correctly the 2005 to 2007 short beds had 28 gallon tanks.
