changing front rotors and pads
Old Aug 27, 2008 | 12:05 PM
freirefishing's Avatar
freirefishing
2006 ranger 4x4 4.0 auto
need to change rotors and pads they have 50k more miles on it,and the rotors were turned once already....so im thinking change them??
i dont want to walk into a brake place or ford to find out if i need rotors or not......every time you walk in to have 1 thing done they try and sell you that 4 things are wrong..........i have done rotors and pads before
what am i looking at??? (not price....but anything i should know about the brakes on a ranger).....is it all standard for most vehicles I.E. clips for the pads etc......rotors just slide on the lug nutz
Old Aug 27, 2008 | 12:39 PM
matt's2.9STX's Avatar
matt's2.9STX
There's another thread with plenty of opinions further down. If you're just doing a basic job & the rotors aren't getting scraped at all & the bearings smooth and snug, just change the pads. Probably should use the break the bleeder technique to push the pistons back in before assembly. Then bleed the air out afterward. And make sure the pistons move easily. Just get a can of brake kleen & appropriate slider lube with the pads. Before doing the job, read the thread for another fella.
Old Aug 27, 2008 | 12:46 PM
hydro_37's Avatar
hydro_37
I would also just change the pads. Here is a great post about brakes Matt was talking about
https://www.ford-trucks.com/forums/7...nt-brakes.html
Old Aug 27, 2008 | 03:36 PM
freirefishing
ill will check it out....but also forgot to tell you that the rotors are grinding,so i know that i have grooves in them.....would have changed em weeks ago....but with finances and such etc...you all know what im talking about
i forgot about the bleeding part of the brakes...man its probably been a good 6-7 years since ive done brakes
Old Aug 27, 2008 | 04:07 PM
pgw85706's Avatar
pgw85706
The only item to be aware of (and I'm not certain if it is a worry or not) but you like have 4 wheel ABS and thus there is a speed sensor in each front wheel. The VSS is magnetic and sits close to the rotor to monitor rotation. People have had problem that with aftermarket rotors the VSS will not detect the tone ring on the rotor.
beidle99
2009 - 2014 F150
Feb 4, 2015 11:39 AM
BaitGuru
Jan 20, 2015 06:53 PM
bigunit54
2004 - 2008 F150
21
Aug 19, 2010 12:14 PM
kgwld1
Dec 15, 2005 09:49 AM
Kurious
2004 - 2008 F150
16
Jun 13, 2005 07:47 PM
