dual alternators
Old Aug 17, 2000 | 09:24 AM
surfbronco79's Avatar
surfbronco79
dual alternators
I'm looking to convert to a dual alternator system for my '79 Bronco. Can anyone suggest a wiring diagram. I would like to use twin 130amp to 140amp units, preferably single wire style.
Thanks.
Old Jan 9, 2001 | 05:22 PM
otto's Avatar
otto
dual alternators
wow what are you running that you need dual alternators ? if they are the sinde wire style couldnt you just hook both of the single wires up to the battery side of the solenoid ?
Old Jan 14, 2001 | 06:59 PM
Mulletwagon's Avatar
Mulletwagon
dual alternators
Interesting mod. I would use a standard alternator with external regulator. Mount the alternator somehow on it's own crank pulley. As for wiring - I would make the second alternator cockpit selectable as follows. Using a standard harness route the alternator field terminal to the regulator "f" tab. Ground wire from alternator to ground on one of the regulator mounting screws. Run a heavy wire from the alternator "bat" terminal to the hot side of the starter solenoid. The "sta" terminal on the alternator is not used. Splice the wires from the regulator "a" and "s" tabs together and run a wire from the splice to a switch on the dash that will provide 12 volts when the alternator needs to be turned on. The "I" tab on the regulator would not be used. Should provide enough juice to fire up a B-52 landing light. Good Luck
Old Apr 21, 2001 | 03:50 AM
quadna711's Avatar
quadna711
dual alternators
long live SAC!!!!
Old Apr 21, 2001 | 04:31 PM
Mulletwagon
dual alternators
>long live SAC!!!!
Actually developed some support equipment for the B-52Hs at Minot last year (1960 models). Still a great old bird.
Disbanding SAC and TAC and rolling the whole ball of wax into ACC ended a great tradition for both the fighter and bomber guys.
I miss the old days !!
USAF 1971 - 1991
Old Apr 21, 2001 | 11:23 PM
quadna711's Avatar
quadna711
dual alternators
mulletwagon,
4 years up at k.i. in michigan before they shut it down. now at dover but have orders to honduras for a 12 month remote. my #1 follow-on pick is minot; still waiting to find out if i get it. born and raised in northern minnesota so only a hop skip across the stateline. need to get my hands on some hydraulic fluid from an old buff to get my blood pumpin' again.
long live the 8 engine!!!
Old Apr 23, 2001 | 10:18 PM
Mulletwagon
dual alternators
>mulletwagon,
>down. now at dover
>find out if i get
>it. born and raised
>again.
I went TDY to Minot in December. Cold, -3 degrees, windy, and everything was covered with snow - even all the Buffs -- Looked like something right out of a Jimmy Stewart movie. The locals love it. They wear t-shirts that read "Minot ND, -65 degrees keeps out the riffraff". The place is flat - infact - they say the state tree is a telephone pole. In spite of that the kids I worked with, mostly loaders, ammo troops, and metal techs, were great and doing a super job. Hope you get a follow-on there. You would be close to home and get to see a real (flying) classic every day.
Aim High
Old Apr 24, 2001 | 03:24 AM
karljay's Avatar
karljay
dual alternators
TAT2DUP81
Mar 2, 2018 02:15 PM
ManfredVonRichtofen
WTB - Parts & other
Jun 6, 2013 07:36 PM
wsnead56
24
Sep 5, 2011 08:29 PM
kilog55
Oct 7, 2007 07:17 PM
tom1979
Electrical Systems/Wiring
Nov 18, 2006 09:21 PM
