Help!! Brake trouble still....
Old Aug 25, 2008 | 08:54 PM
67lunargreen's Avatar
67lunargreen
I have replaced all the brakes except the proportioning valve, even some of the hard lines. I replaced the master, wheels, and booster. Still the brake pedal is soft after a block. I can pump up the brakes and they are fine. Next time the pedal is soft. I have bled the propoortioning valve, master, wheel cylinders. Vaccum bled and hand bled. Still get bubbles on the vaccum pump. No undulating big bubbles but small bubbles. I have adjusted the self adjusters. Any help would be great.
Old Aug 25, 2008 | 09:28 PM
BobbyFord's Avatar
BobbyFord
You still have air trapped in the system somewhere.
Old Aug 25, 2008 | 09:49 PM
67lunargreen
correct bleeding order?
I am bleeding passenger rear, driver rear, passenger front, driver front. Is that the correct order?
Old Aug 25, 2008 | 10:07 PM
BobbyFord's Avatar
BobbyFord
Yes, that is correct
Old Aug 25, 2008 | 10:10 PM
67lunargreen
i'll keep bleeding
I will bleed it some more. I will just start over at the master and go all the way down. Thanks.
Jeff
Old Aug 26, 2008 | 02:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 67lunargreen
I will bleed it some more. I will just start over at the master and go all the way down. Thanks. Jeff
I'm not 100% sure, but doesn't the proportioning valve need to be bled too?
I know on the later trucks this is required.
Old Aug 26, 2008 | 09:29 AM
Freightrain's Avatar
Freightrain
I've never bled a proportioning valve, but never seemed to have to either.
If you still got air bubbles, then you still need to bleed them more. You're doing it in proper sequence(fartherest to nearest). Sometimes brakes can be the devil to get bled all the way.
Old Aug 26, 2008 | 11:12 AM
67lunargreen
I am going to start over
I am going to bleed the master, portortioning valve all the way down the line, I am also going to check all the lines againg and the fittings. I have never had such a hard time.... I also never have had to replace hard lines, or some one's prior attempts. I have only messed with stock to new replacement parts. This truck seems to have had a lot added to it, I have ripped out the trailer brake booster and many bent hard lines. Thanks for the encouragement, I thought I was doing something horrible wrong or forgetting a step. I might have missed something but we will see. Wish me luck for off I go.
Jeff
Old Aug 26, 2008 | 02:27 PM
blue68f100's Avatar
blue68f100
Are you using a brake bleeder, or doing it Manually. Manually pumping the brakes and aggatate/airiate the fluid. You can get power bleeders for < $100 these day. The once and your done. No need for a second person.
Old Sep 2, 2008 | 07:54 PM
pappie's Avatar
pappie
hey, did this guy ever get his brakes?
Old Sep 3, 2008 | 01:43 AM
68 ranger's Avatar
68 ranger
Why, Good after nooooooooon. I do believe that there is a PIN on
the perportioning valve its self, that MUST BE HELD OPEN it looks
like a rivet, but you can make a tool to hold it open. it should be held
open thru the entire bleeding prosses. I hope this helps!
Old Sep 4, 2008 | 11:02 AM
DavidB's Avatar
DavidB
The "air bubble" has a tendency to rise. Sometimes on a "stubborn" system, it helps to lift the end of the vehicle you are bleeding as much as reasonably possible before bleeding and it seems to help to get the air out better as you bleed the system. Just keep bleeding it until you get it all out.
Old Sep 4, 2008 | 11:18 AM
67lunargreen
Got It!!!
I just started over at the master and went through everything. I don't really know what was wrong but I fixed the problem. It is now registered and on the road. I might even take it to work tonight. Thanks for all your help!
Jeff
Old Sep 4, 2008 | 06:55 PM
68 ranger's Avatar
68 ranger
That's what we're here for
