Tilt steering mounts?
Old Aug 25, 2008 | 05:07 PM
RUSTY50F1's Avatar
RUSTY50F1
Anyone have any pics of the way you mount a tilt column. As far as braces or brackets. I tried to find a drop down with a single hole for it but with all the wires and rods, I don't think that would work. Anything would be a big help. Thanks RUSTY
Old Aug 25, 2008 | 06:02 PM
49willard's Avatar
49willard
Claude, I have one picture in my Gallery in the album for Ranger seats that has my Tilt column mounted to the bottom of the 49 dash. The column is out of a 70's t-bird. I fabricated the mount.
Old Aug 25, 2008 | 06:28 PM
jniolon's Avatar
jniolon
old and in the way
here's mine
Installing a IDIDIT ColumnIn a
later
John
Old Aug 25, 2008 | 06:41 PM
Kusto's Avatar
Kusto
Here is the one I built. Used the old hanger from the chev column and cut the tabs off, then used angle iron to build the new tabs that mount to the dash.
Hope this helps.
Old Aug 25, 2008 | 07:31 PM
RUSTY50F1's Avatar
RUSTY50F1
Thanks fellas; That tells me what I needed to know. Can't do the ididit not in the truck budget. Sorry;
Old Aug 25, 2008 | 09:14 PM
sparky's Avatar
sparky
I did the "Rodder" thing again....... used what I had in the shop ..... mounted 2 muffler clamps to secure the Ford tilt column in my 53, one under the floor and the other goes thru the old steering column drop bracket. Rock solid steady and pretty much invisible after paint..... plus it was cheap
Old Aug 26, 2008 | 12:09 PM
firstrider's Avatar
firstrider
Very clean & easy install for a G.M column in '48-'52 F-1 truck . This is the item that was used on the 1ST-RIDE to install a '80 Eldorado tilt /tele column .See pic in gallery .Sacramento Vintage Ford ( where I spent way too much $$ ) item # 7217-1 . No modifications required $50.00
Old Aug 26, 2008 | 10:34 PM
Kusto's Avatar
Kusto
Mine was free since I had the materials around the shop and....no waiting for parts.......priceless
